Toymods » General Car Talk » celica rim size
havabeer
new castle
July 2005
celica rim size Tue, 13 September 2005 03:16 Go to next message
hi just a quick question
just wondering what is the wheel off set and what size rims will fit on my ST162 celica. or how i can go about finding this out, my haynes manual wasnt to helpful.
ST162GT-R
QLD, Gold Coast
Re: celica rim size Tue, 13 September 2005 03:25 Go to previous messageGo to next message
i believe st162 SX had a 5x100 offset on the top of my head, rim size can be as large as 18", but i wouldn't recommend it as 17" are bad enough for me.
havabeer
new castle
July 2005
Re: celica rim size Tue, 13 September 2005 03:44 Go to previous messageGo to next message
so 5x114.3 wont fit?
Corona RT142
Campbelltown
Re: celica rim size Tue, 13 September 2005 03:47 Go to previous messageGo to next message
havabeer wrote on Tue, 13 September 2005 13:44
thats a pretty good assumption Razz
st184 sillycar
Re: celica rim size Tue, 13 September 2005 04:46 Go to previous messageGo to next message
Corona RT142 wrote on Tue, 13 September 2005 13:47
Hell no! You won't get the wheel studs through the holes. Check your offset too (search these forums, or the stamping on your rims).
You'll have to check your inside clearance to the struts for backspacing (how low you can go on offset) and your clearance to the guards (how high) . . . . but I expect that's all been covered in detail many times over ! Very Happy
ST162GT-R
QLD, Gold Coast
Re: celica rim size Tue, 13 September 2005 04:47 Go to previous messageGo to next message
It may..but i don't think you will have much thread for the bolts to go on, therefore leaving it very dangerous and the wheels more the likely to come off while driving
Corona RT142
Campbelltown
i ment its a pretty good assumption that the 5x114.3 won't fit cos they won't ahahhahaha you is silly hence your name Laughing
matt86sx
Gold Coast, QLD
Re: celica rim size Tue, 13 September 2005 05:20 Go to previous messageGo to next message
The stud pattern on an ST162 is 5x100, meaning 5 studs spaced equally on a circle of diameter 100mm. A rim with a 5x114.3 hole pattern will not fit, period.
The standard offset for the ST162 is +39mm. (You can find this cast into the wheel under the centre cap, if you still have the original rims.) Check the diagram below for an explanation of offset:
http://img.photobucket.com/albums/v636/macca_1972/offset.gif
In addition to moving the rim inwards (when the offset is increased) or outwards (when decreased), changing the offset will also change the track width, ie the distance between the rim centrelines measured across the car. Changing the track width may be illegal for you so it would be wise to check. For instance in QLD you can increase the track width up to 26mm (ie 13mm per side) but not decrease it.
Hope that helps.
Matt
[Updated on: Tue, 13 September 2005 05:23]
smashed_wombat
Re: celica rim size Tue, 13 September 2005 07:12 Go to previous messageGo to next message
lol - how many times has this been asked now? Laughing
matt86sx
Gold Coast, QLD
Re: celica rim size Tue, 13 September 2005 23:39 Go to previous message
WAY too many. I can just about type that reply now with my eyes closed Laughing
But since there was some pretty bad misinformation earlier in the thread I figured I had better clear it up before someone tried to fit 5x114.3 rims to a Celica. And sometimes trying to dig up and old thread and post a link can take more time than typing a response.....either that or my search skills need some work. Confused
Matt
Previous Topic:World NO OIL Day!!
Next Topic:IJZ 747 on zoom cover
Current Time: Thu Nov 19 09:00:23 UTC 2026
Total time taken to generate the page: 0.0064117908477783 seconds
