Toymods » Tech & Conversions » 3sgte coolant pipe arrangement
3sgte coolant pipe arrangement Tue, 13 September 2005 06:25 Go to next message
Howdy all, this is in regards to my 3sgte rwd conversion.
Basically all the external coolant lines need to be remade/altered etc.
Originally it appears there are 3 coolant lines going back into the water pump, with the water direction flowing into the pump. I assume some of these are required to go back to the pump to heat up the thermostat?
1 comes out of the inlet side of the block, goes through the oil cooler, then into the pump. Lets call this coolant-1.
1 comes out of the water outlet at the back of the head, goes straight to the water pump. coolant-2.
Another goes from water outlet back of the head, through the heater, and returns to the water pump. coolant-3.
Now would my idea here work.........
coolant-1 will no longer go via the oil cooler, as i'm using an external air cooled cooler. instead, i'll use this as the hot water into the heater. once through the heater it will go back to the pump.
coolant-2 will remain the same, out the back of the head and straight into the pump, assuming my assumption above is correct about this being required to heat up the thermostat. If that assumption is wrong, maybe coolant-2 isn't needed.
coolant-3 no longer required as i'm using coolant-1 for this. So that would mean blocking up the pipe running into the pump.
Reason for using coolant-1 and not coolant-3 for the heater is the pipe is already coming out of the block.. and any extra pipes coming out the back of the head is a custom fabrication job due to the rwd space restraints.
joel
[Updated on: Tue, 13 September 2005 06:28]
Re: 3sgte coolant pipe arrangement Tue, 13 September 2005 08:33 Go to previous messageGo to next message
Your coolant-3 would of also been for the turbo.
Your idear will work but make sure you do keep coolant-2 as this does help the thermostat work and also helps air exit the engine.
[Updated on: Tue, 13 September 2005 08:34]
Blackers
Forrestdale W.A.
Re: 3sgte coolant pipe arrangement Wed, 14 September 2005 04:39 Go to previous messageGo to next message
Be careful if you need an efficient heater as the water coming out of the H2O pump will be at a reduced temp as compared with the rear of the head. If you use coolant 3 for the turbo, where would you plumb it back to?
Mark
Re: 3sgte coolant pipe arrangement Wed, 14 September 2005 05:22 Go to previous message
Howdy thanks for ideas so far..
The turbo i'm running isn't water cooled, so no need to feed that.
With the heater pipes, the coolant-1 i mentioned that i thought to use for heater, that comes out the rear of the block around cyl no4. i thought by then it'd be pretty hot?
Previous Topic:4agze piston rings
Next Topic:Mystery oil leak
Current Time: Sun Jun 7 18:43:05 UTC 2026
Total time taken to generate the page: 0.0056660175323486 seconds
