Toymods » Tech & Conversions » 4AGZE clutch options
AE92gze
June 2005
4AGZE clutch options Tue, 13 September 2005 20:25 Go to next message
Hey all,
I need some advice about 4agze clutches. First what clutches do you guys run or recommend? And secondly where about in the Sydney area sells gze clutches? Thanks in advance
mighty_boy
Re: 4AGZE clutch options Wed, 14 September 2005 06:19 Go to previous messageGo to next message
i got my mechanic (jax) to replace mine with a standard clutch. I think it was a daikin, theres a few that they make that should fit. Really depends on how much power your running and how you treat it. Im running 10psi (i think) and drive sensibly and had no problems with the old clutch. Even after going to wakefield it was fine. Just run some good clutch fluid and it should hold well.
Speak with 4agte for further advice or any of the aw11 mr2 guys Smile
4agte
Toronto, Downtown
Re: 4AGZE clutch options Wed, 14 September 2005 06:50 Go to previous messageGo to next message
depends on your driving style and the power you want to make but for stock a daiken stock replacement will work no worries anything modified that gets given a bit of stick you should be looking at a daiken heavy duty
Edit: if you wanna turbo it or intend on doing some drag racing even circuit racing then you should look at a button style clutch. The exedy buttons are very easy to use.
[Updated on: Wed, 14 September 2005 06:51]
inertia
We put an Exedy HD Organic in mine, time will tell if my noobness kills it quickly or not.
AE92gze
June 2005
Re: 4AGZE clutch options Wed, 14 September 2005 07:09 Go to previous messageGo to next message
What about pressure plates?
bayka
perth
Re: 4AGZE clutch options Wed, 14 September 2005 08:32 Go to previous messageGo to next message
The pressure plate comes with the clutch kit. You may be able to get just the clutch face as a replacement but it always makes sense to replace everything while you can. (ie new thrust bearing that comes with clutch kit, and rear main seal that goes behind the flywheel)
The exedy Heavy Duty clutches have stronger pressure plates. (my old one was 30% more clamping force)
? dont understand ur question
-daniel-
inertia
Re: 4AGZE clutch options Wed, 14 September 2005 10:06 Go to previous messageGo to next message
Indeed, kit came with uprated pressure plate and replacement bearing... cost was $365 from memory.
kingmick
Banned by his request
moved to tamworth
Re: 4AGZE clutch options Wed, 14 September 2005 10:35 Go to previous messageGo to next message
give johny at western clutches a ring in blacktown.tell him you want a exedy ceramic button,they work a treat and are not like a normal button.
mick
AE92gze
June 2005
Re: 4AGZE clutch options Wed, 14 September 2005 14:12 Go to previous messageGo to next message
Will a button clutch be annoying to daily drive with? Coz the cars goin to be a daily driver. Also do you have western clutches phone number
4agte
Toronto, Downtown
Re: 4AGZE clutch options Wed, 14 September 2005 21:43 Go to previous messageGo to next message
no exeedy ceramic button clutches are not a problem to drive everyday. I use mine constantly and with on in my car i drove to work 5 days a week in peak hr traffic for about a year.
Re: 4AGZE clutch options Wed, 14 September 2005 22:06 Go to previous messageGo to next message
the exedy ceremetallic puk clutches are what you want... they aren't a button style clutch really, as the paddles (or "puks") dont have big brass buttons thru them.
That said, they are decent as the allow a good degree of slip whilst still holding up to some dececnt power numbers. I would personally go a 5 puk as the least number of puks for a FWD.
Next question - do you have the 225mm or 230mm flywheel? Diaken does not have a clutch available for the 230mm flywheel at all, since both the clutch disc and pressure plate are different!!
4agte
Toronto, Downtown
Re: 4AGZE clutch options Wed, 14 September 2005 23:09 Go to previous message
THE WITZL wrote on Thu, 15 September 2005 08:06
on both occasions i have spoken to exedy they called my clutch a 3puk ceramic button clutch. But having said that they dont act like any other brass button clutch i have used
Previous Topic:4age crank pully compatibility
Next Topic:Any engine builders / machinest out there heard of a Bourke Engine or a Very Lean Burn Engine?
Current Time: Fri Oct 16 15:34:27 UTC 2026
Total time taken to generate the page: 0.017447948455811 seconds
