Toymods » Tech & Conversions » Weird Knock in 4AGE
rollaboy
Coffs
Weird Knock in 4AGE Wed, 01 January 2003 07:06 Go to next message
Hey guys,
My engine is in now and i started it for the first time. Found a water leak coming from under the Throttle Body area.
Then the next day i started it again to go for a test drive as i just bled the brakes and it had no water leaks but a new knock started from around the cam gear, timing belt, tappet cover area. Sounds like metal nipping metal as something goes around.
I changed the timing belt to if that helps.
Anyone got any ideas what it could be.
rollaboy
Coffs
Re: Weird Knock in 4AGE Wed, 01 January 2003 10:43 Go to previous messageGo to next message
OK had another listen to it this afternoon and i have got it down to the inlet cam gear area just not sure what is making the noise. Only happens when revs build up and or it engine shakes more then at a smooth idle.
Sounds kinda like the cam gear/sprocket it hitting one of the bolt head behind it. Dont ask me how its doing that.
Also that side looks like it wobbles a bit more then the exhaust cam.
I really need ur help. Dont want to drive car like it is.
ROBBO_ma61
Re: Weird Knock in 4AGE Wed, 01 January 2003 11:22 Go to previous messageGo to next message
Is it in the bottom end? if so...some knocking sounds can be signs of a spun big end bearing
rollaboy
Coffs
Re: Weird Knock in 4AGE Wed, 01 January 2003 11:26 Go to previous messageGo to next message
Nah sounds not in the bottom end.
The werid thing is it was ok why i took the engine out.
And i have only changed the timing belt.
ROBBO_ma61
Re: Weird Knock in 4AGE Wed, 01 January 2003 11:29 Go to previous messageGo to next message
Any bearings anywhere that could be fukt? Head gasket can cause the problem of the shaking and sick sounding...mates got a 626 mazda hg blown on it..fucken is running on 3 cylinders lol
Julz
Re: Weird Knock in 4AGE Wed, 01 January 2003 11:53 Go to previous messageGo to next message
Water leak may be coming from the heater, where the heater hose attached to the piping in the firewall. It's copper so it's a bit delicate. maybe u accidently crimped it.
rollaboy
Coffs
Re: Weird Knock in 4AGE Wed, 01 January 2003 12:02 Go to previous messageGo to next message
No water leak now. Dont know why just isnt.
The heater pipe is just in a loop so theres no coolent going past there. The stupid heater felt like it was on all the time so i did that.
TE72_Turbo
Re: Weird Knock in 4AGE Wed, 01 January 2003 13:49 Go to previous messageGo to next message
have you checked that the bolt holding each cam gear to the cams are tight? The gear will flog itself back and forward on the locating dowel if it is not. They should be torqued to 43 ft/lb.
CHeers
Phil
raSkaS
Perth WA
Re: Weird Knock in 4AGE Thu, 02 January 2003 03:34 Go to previous messageGo to next message
Id be cheaking that the cams are getting a good supply of oil to them, while you were doing the T/Belt was the oil baths under the cams full ?,ive heard of 4ages with no oil in the head having real trouble getting the pump to start to supply up top because of an air block
Cam
rollaboy
Coffs
Re: Weird Knock in 4AGE Thu, 02 January 2003 22:49 Go to previous message
raSkaS wrote on Thu, 02 January 2003 14:34
Havn't done that.
I think the bearings in the idler pulley are shot.
But still don't think they would make that kinda noise.
Damn wish I could record it some how.
Previous Topic:Help - Removal of Chrome strips
Next Topic:guys with 1G's running thermofans?
Current Time: Fri Nov 20 07:32:01 UTC 2026
Total time taken to generate the page: 0.01027512550354 seconds
