Classifieds » Parts Wanted » AW11 hub parts & water to air - water cooler (radiator)
nick.parker
January 2005
AW11 hub parts & water to air - water cooler (radiator) Wed, 14 September 2005 07:36 Go to next message
Hi I am after the following things:
A Supercharged-AW11 Left Rear Hub (thing with wheel studs.)
I am also seeking a water to air intercooler radiator from a as the air-con expander I currently use isn't cooling the water enough.
Cheers, Nick.
._T_.
Re: AW11 hub parts & water to air - water cooler (radiator) Wed, 14 September 2005 22:30 Go to previous messageGo to next message
nick,
i have a s/c hub assembly. also have new wheel bearings as well if that helps.
got several water/oil heat exchangers, but no radiators.
T
nick.parker
January 2005
Re: AW11 hub parts & water to air - water cooler (radiator) Thu, 15 September 2005 00:48 Go to previous messageGo to next message
Thanks for the reply.
If its good, I'm interested in the whole left rear hub assembly.
What parts does it comprise of. Possibly interested in one wheel bearing too for that hub. What sort of $ are you after?
Cheers, Nick
._T_.
Re: AW11 hub parts & water to air - water cooler (radiator) Thu, 15 September 2005 05:32 Go to previous messageGo to next message
nick,
i have 3 options for you.
compete hubs (disks & calipers are also available but will be extra)
1 - requires wheel bearing (disasembled, done 189k but got wet) $50 + freight
2 - as yet to be removed from aw11 s/c 1/2 cut, appears to be perfect (traveled 147k)$100 + freight
3- wheel bearing & seal kit to suit aw11 mr2 $99
anything else you are after?
T
nick.parker
January 2005
Re: AW11 hub parts & water to air - water cooler (radiator) Thu, 15 September 2005 08:21 Go to previous messageGo to next message
Do 2 & 3 include the cast bit that the bearing is pressed into as well as the hub?
I don't need disk or caliper, so no problem.
I'd likely get '3' aswell.
Whats you phone number? I'll give you a call.
Regards, Nick.
._T_.
Re: AW11 hub parts & water to air - water cooler (radiator) Fri, 16 September 2005 04:17 Go to previous messageGo to next message
hi nick,
1 & 2 are upright assembly inc hub.
3 is a replacement bearing & seals kit
follow below link to get to our web site
T
nick.parker
January 2005
Re: AW11 hub parts & water to air - water cooler (radiator) Tue, 20 September 2005 09:00 Go to previous messageGo to next message
How are things going with extracting that left rear upright assembly?
I'll give you a call tomorrow.
Bobski
Re: AW11 hub parts & water to air - water cooler (radiator) Tue, 20 September 2005 09:32 Go to previous message
Hi
I have a whole NA mr2 which has been recently rolled Rolling Eyes it has everything on it including radiator, u purchased parts off my friend before (Bayka with the red ae92) I know this car is not supercharged but maybe there are parts you need....
either message me back or call him...he has my number
Adam
Previous Topic:Anyone got spare or not using their TEIN Key's/Spanners?
Next Topic:WTB: 4x114.3 rims-ANY TYPE!!!
Current Time: Mon Oct 26 13:28:53 UTC 2026
Total time taken to generate the page: 0.004767894744873 seconds
