Toymods » Tech & Conversions » 18RG Questions
CamZH
Toodyay, WA
18RG Questions Wed, 01 January 2003 08:23 Go to next message
Hey guys,
I've got the 18RG out of the TA22 now, and have started to have a good look at it...
Got some questions...
http://members.optushome.com.au/manjuice/oil%20breather.jpg
what is that?? crank case ventilation?? should it be conected? the normal 18R just has a plank plate over this bit.
http://members.optushome.com.au/manjuice/exhaust%20ports.jpg
and whats the go with the exhaust ports? what are these funny little dimples? are the from the bolts just below the ports? is it normal to hvae the head of the bolts ground down to make the extractors fit?? what do the bolts even do??
Thanks,
CamZH
[Updated on: Wed, 01 January 2003 08:24]
Jonny2TG
Tasmania
Re: 18RG Questions Wed, 01 January 2003 10:32 Go to previous messageGo to next message
Crankcase ventilation thap pipe probably is. You can keep it blocked up, unless you want to run a normal PCV valve back to the inlet manifold, for polution reasons. Just make sure the vent on top of the cam cover is vented somewhere and not blocked. You can either put a filter on it, or just have a hose going back behind the engine facing the ground. Or you can have the top hose going to a catch can, and another hose to the catch can from the crank plate vent if you want.
The big bumps in the floor of the exhaust ports, are ment to be there. But no one knows why. It is solid aluminium though and when porting those heads, people grind them down flush.
Issues with extracters will depend on the brand. Do what you think is right.
CamZH
Toodyay, WA
Re: 18RG Questions Wed, 01 January 2003 11:14 Go to previous messageGo to next message
Thanks for the info Jonny.
but the bits in the exhaust port are acutally little depressions. not bumps!
if it was a little bump i'd probably grind it down myself Smile
but the ports feel very good as they are, i dont know if they have seen a die grinder before or not.
CamZH
CelicaRA45
nth ringwood, Victoria
Re: 18RG Questions Wed, 01 January 2003 11:25 Go to previous message
thats a 18rgu pollution head with air injection or air pump set up it had 4 holes that went to every ex port it should be 8.3 comp also in the 1st pic is for the pvc it fitted near the inlet across to the carbies
Previous Topic:Corolla Question
Next Topic:2S Corona info
Current Time: Sun Oct 25 22:27:00 UTC 2026
Total time taken to generate the page: 0.0037009716033936 seconds
