Toymods » Tech & Conversions » wheel bearings
nick2b
icon10.gif  wheel bearings Wed, 14 September 2005 22:32 Go to next message
Hey, im about to change the rear bearings on my car its FWD are their any tips i could have please.
20VBTSECA
May 2005
Re: wheel bearings Thu, 15 September 2005 00:28 Go to previous messageGo to next message
its not a fun job. Good luck Smile
berad
Re: wheel bearings Thu, 15 September 2005 03:08 Go to previous messageGo to next message
lots of grease , did i mention more grease Razz... i used to love greasing up bus wheel bearings when i was a work experiance bitch. *thumbs down*
mr_ke30
Re: wheel bearings Thu, 15 September 2005 09:32 Go to previous messageGo to next message
hahaha get a palm full of grease and push the bearing onto it and keep doing it till it oozes out the other end called packing the bearings!! have fun
Re: wheel bearings Thu, 15 September 2005 12:00 Go to previous messageGo to next message
You'll probably need a press...
xpimp
melbourne
Re: wheel bearings Thu, 15 September 2005 12:40 Go to previous messageGo to next message
Have personally done this twice without a press.
Not a fun job!!! and I would think it would sometimes end up with an unreliable result.
Find someone with a press who will do it for you, otherwise it will take roughly an hour to carefully tap it down Mad
nick2b
Re: wheel bearings Thu, 15 September 2005 12:55 Go to previous messageGo to next message
LOL 1 hour for 1 bearing or all 4 bearings. ill be happy if it takes 1 hour for al 4 bearings
xpimp
melbourne
Re: wheel bearings Thu, 15 September 2005 13:28 Go to previous messageGo to next message
1 for 1...
You need to angle grind down the side of an old inner race to act as your press (which you will tap with a hammer)
So that way you can get the inner race off once you tap it all the way down
shelldrake
parkdale, Victoria
May 2005
Re: wheel bearings Fri, 16 September 2005 06:30 Go to previous messageGo to next message
It can be done w/out a press. When you grind the old one off it should heat up before you get through and you should be able to slide it off. Use a steel tube on the inner race when hitting it down. An even amount of pressure will be applied each time that way. Use a brick hammer.(Has a bigger face on it). Heaps quicker than tap tap tapping around the edges. Good luck, allow enough time. Wink
nick2b
Re: wheel bearings Sat, 17 September 2005 02:02 Go to previous message
im just about to start pulling it off. I dont understand why i have to grind it off, why cant i just use a claw and pul it off?
Previous Topic:How do I stop Turbo Compressor Surge???
Next Topic:ST162 Temp gauge question
Current Time: Fri Oct 30 19:51:29 UTC 2026
Total time taken to generate the page: 0.0071070194244385 seconds
