Toymods » Tech & Conversions » 2tg timing
fallenangel
Wollongong NSW
2tg timing Thu, 15 September 2005 11:21 Go to next message
can someone lead me in the right direction with this.... i set the cam flanges straight up on top dead centre. when timing chain is tensioned it pulls inlet cam around about 40 degrees and leaves exhaust cam facing upwards... i havent timed a twin cam before and am curious if this is correct or does the inlet cam have to stay facing up when the chain is tensioned? motor at TDC when set cams.
September_Squall
Melbourne, Australia
March 2005
Re: 2tg timing Thu, 15 September 2005 13:36 Go to previous messageGo to next message
At TDC and all assembled the notches in the cams should be straight up. I think there's also a punch mark in the #1 cam bearing cap. Maybe try removing the sprocket from the cam, rotate the cam to the intended timing, then install the tensioner and install the sprocket after that?
fallenangel
Wollongong NSW
Re: 2tg timing Thu, 15 September 2005 13:47 Go to previous message
okies...will try in morning
Previous Topic:MA61 strut braces
Next Topic:4age head -gze block
Current Time: Tue Oct 27 13:04:17 UTC 2026
Total time taken to generate the page: 0.0037739276885986 seconds
