Toymods » Tech & Conversions » Pick up in distributor
Slippy
March 2005
Pick up in distributor Fri, 16 September 2005 01:20 Go to next message
4age out of JDM.
Auto Elec thinks that the pick up in the dist is stuffed.
Does anyone know if the pick up is INDUCTIVE or HAUL?
Much appreciated if someone could help.
Also, does anyone know where I can print off the diagrams for all the fault codes for the 4age jap version?
Thanks.
stradlater
Arthurs Creek, Victoria
Re: Pick up in distributor Fri, 16 September 2005 06:15 Go to previous message
If the 4age dizzy is anything like the 1g (which I think it will be) then it's most DEFINATELY inductive, not Hall effect, because the hall effect ones don't BREAK like the toyota inductive ones do.
Whilst it may cost a little bit of money, it'd be well worth your while converting it to a hall effect sensor, that is unless your using the standard ECU.
Previous Topic:Can blowing your diff damage your gearbox???
Next Topic:what clutch good for sprinter?
Current Time: Tue Oct 27 10:35:12 UTC 2026
Total time taken to generate the page: 0.023550987243652 seconds
