Toymods » General Car Talk » brake problem
ae86_boy
brake problem Fri, 16 September 2005 06:05 Go to next message
hey guys having a bit of trouble with the brakes on my sprinter, i just changed the pads. And now when i brake the pedal moves back and forward a bit, like shuddering. Any ideas what it might be?
Henn
Rosanna, Melb
Re: brake problem Fri, 16 September 2005 06:37 Go to previous messageGo to next message
Sounds like your disks need machining as they're slightly warped.
Hen
ae86_boy
Re: brake problem Fri, 16 September 2005 06:40 Go to previous messageGo to next message
nah couldnt be dude, i just had then machined too, today.
Henn
Rosanna, Melb
Re: brake problem Fri, 16 September 2005 06:58 Go to previous messageGo to next message
Make sure its all bolted up straight and tight then. You can check the disk runout with a dial gauge if you can get your hands on one.
ae86_boy
Re: brake problem Sun, 18 September 2005 09:24 Go to previous messageGo to next message
i think im gunna get some new ones from DBA, anyone know the part numbers. Do DBA make the gold ones that are slotted for the Ae86??
Re: brake problem Sun, 18 September 2005 09:49 Go to previous messageGo to next message
before you do that, go ove the surface of the iscs and the pads with emery cloth (or rough wetndry) and rebed the pads in properly.
the "warpage" feelign you get is 99% of the time just uneven transfer of resin from pads to the disc...
clean em off, rebed them to the pad manufacturer specs, (remember NOT to come to a stop while letting them cool)
and see how they are...
if it is still there, then check or disc runout.
if there is no runout, then it MUST be resin on the disc..
what pads are they? not EBC gren?
illuminatus
eastern suburbs, melbourne
March 2005
Re: brake problem Mon, 19 September 2005 03:14 Go to previous messageGo to next message
is there a problem with ebc green?
Re: brake problem Mon, 19 September 2005 03:19 Go to previous message
no, just that many ppl seem to have issues when they get them too hot, due to excessive resin transfer....
but if you use them they way they are intended, they are great pads i suppose..
Previous Topic:What to buy?
Next Topic:Any sites to find holden VL's ?
Current Time: Thu Nov 19 14:58:32 UTC 2026
Total time taken to generate the page: 0.0065858364105225 seconds
