Toymods » Tech & Conversions » 1JZ questions
splatt
Inner west,Sydney
1JZ questions Fri, 16 September 2005 07:23 Go to next message
What is the blanking plate on the left hand side (rear) of the alloy sump surround for??
What sort of money are the big rubber engine mounts (JZ100)second hand/new worth to replace each? and are they the same, soarer and Chaser? -they have one bolt to alloy engine bracket. two to sub frame.
[Updated on: Sat, 17 September 2005 07:13]
ChuckLandwehr
Re: 1JZ questions Sat, 17 September 2005 05:47 Go to previous messageGo to next message
Answer to Question 1, If it has two bolts holding a small plate on, then that is where some 1J's mount an oil level sender.
cheers Chuck.
splatt
Inner west,Sydney
Re: 1JZ questions Sat, 17 September 2005 06:40 Go to previous messageGo to next message
Plate is approx 40mmx40mm 4 bolts.
Skip
Re: 1JZ questions Mon, 19 September 2005 00:20 Go to previous messageGo to next message
Yeah that would be where the oil level sender is mounted.
wilbo666
Re: 1JZ questions Mon, 19 September 2005 00:35 Go to previous messageGo to next message
Yep, oil level sender is 4 bolts, and approx those dimensions.
splatt
Inner west,Sydney
Re: 1JZ questions Mon, 19 September 2005 08:07 Go to previous messageGo to next message
Thanks, I have enough wires to reroute now without an oil level light.
Question about mounts, The two I have are A1, but thought I'd price them before I made up special mounts for them for my engine swap. Got a new price from Castle Hill Toyota, $260 each. I can set conversion up with much cheaper items, the JZX100 ones are listed in for sale if anyone needs them.
Manny
Re: 1JZ questions Mon, 19 September 2005 08:32 Go to previous messageGo to next message
Chaser and Soarer/Supra mounts are somewhat different
Soarer/Supra only have one central large bolt to subframe instead of the two smaller ones on the Chaser
splatt
Inner west,Sydney
Re: 1JZ questions Mon, 19 September 2005 21:51 Go to previous message
thanks, there is also a difference(Chaser part numbers) betweem manual and auto, I'm at the stage where I can set up to use much cheaper alternatives.I had a Z32 that Nissan reconned a single mount was worth $300 plus, After market urethane $300plus a pair,(urethane does not key well to bolts,total waste of money,lucky to get a year out of them) Xjs Jag with a spacer cost me $70 for the pair.Worked brilliantly.Time to go buy another set.
[Updated on: Mon, 19 September 2005 21:52]
Previous Topic:3T-GTE problems - reving out
Next Topic:2TGEU + T50 into a AE85
Current Time: Thu Nov 19 15:31:02 UTC 2026
Total time taken to generate the page: 0.0081322193145752 seconds
