Toymods » Tech & Conversions » A/C wiring gremlins
smashed_wombat
icon9.gif  A/C wiring gremlins Sat, 17 September 2005 03:28 Go to next message
I have a weird problem with my 3S-GE Gen III swap. When running normally it does the following:
- after coming to a stop (clutch in), the idle says up around 1100 for 5 seconds before dropping to 800 - 900. I've been told this is normal.
- cold idle is up around 1500.
After using the Air Conditioner the idle up when coming to a stop doesn't kick in, revs instantly drop to 800 as soon as you take your foot off the accelerator (clutch in) and the cold idle is much lower - about 1000rpm. The engine is also feels much less responsive and the fuel economy is pretty average. The engine runs like this until you reset the ECU and the idle settings go back to how they were before using the A/C.
I think the problem is related to how I wired up the A/C. The gen 3 ECU has 2 other inputs from the A/C amplifier (ATS and ACT on the wiring diagram) whereas the gen 1 A/C amplifier doesn't communicate with the ECU at all (besides the clutch signal). The differnce being that the Gen 1 amplifier controlled the A/C idle-up without the ECU, whereas the Gen 3 amplfier must've relied on the ECU to do this.
What do you guys reckon I should do? Is there some way I can get the A/C working without messing up the normal idle? I was thinking of reconnecting the A/C amplifier idle-up VSV in place of the ECU controlled VSV, but would this confuse the ECU?
Sorry for the long post - but this has been annoying me for ages! Any help would be much appreciated.
Thanks,
Andy
smashed_wombat
Re: A/C wiring gremlins Sat, 17 September 2005 10:45 Go to previous messageGo to next message
Does anyone know what the ATS and ACT pins actually do?
smashed_wombat
Re: A/C wiring gremlins Tue, 20 September 2005 08:08 Go to previous messageGo to next message
No one has any ideas? It now idles at 400rpm after using the A/C. Sad Gonna be a pain in the butt come summertime!
sideshow
Re: A/C wiring gremlins Tue, 20 September 2005 12:29 Go to previous messageGo to next message
if u come up to sydney i can look at it for u heheh
smashed_wombat
Re: A/C wiring gremlins Tue, 20 September 2005 14:10 Go to previous message
hmmm... thanks for the offer, but given current fuel prices it might be a bit out of my price range. Smile
Previous Topic:Strange coil voltage readings at ignition coil ?
Next Topic:Deleted
Current Time: Tue Nov 3 16:37:57 UTC 2026
Total time taken to generate the page: 0.061834096908569 seconds
