Toymods » Tech & Conversions » Twin injection benefits?
Switch to threaded view of this topic Create a new topic
Dorio86
Bankstown
August 2005
Twin injection benefits? Sat, 17 September 2005 05:31 Go to next message
What would the benefits of having a twin injection car?
I can't find much information on google, the alfa romeo has twin injection engines, but there isn't much information about it.
It looks like this subject is a bit taboo.
Any information on how to tune and modify the engine to suit twin injection and the pros and cons of it?
Re: Twin injection benefits? Sat, 17 September 2005 05:57 Go to previous messageGo to next message
Dorio86 wrote on Sat, 17 September 2005 15:31
what is twin injection?
where you have two sizes of injectors?
please clarify your question
Dorio86
Bankstown
August 2005
Re: Twin injection benefits? Sat, 17 September 2005 06:03 Go to previous messageGo to next message
Im not sure either, it could be two spark plugs per cylinder.
Dorio86
Bankstown
August 2005
Re: Twin injection benefits? Sat, 17 September 2005 06:05 Go to previous messageGo to next message
http://www.ubergizmo.com/15/archives/2005/08/petit e_package.html
this car has twin injection.
Re: Twin injection benefits? Sat, 17 September 2005 06:07 Go to previous messageGo to next message
the lombardini engine is a twin injection DIESEL engine.
what are you trying to ask?
alfa have twin spark, but so did the 3TGTE. top fuel cars also have twin spark Razz
Dorio86
Bankstown
August 2005
Re: Twin injection benefits? Sat, 17 September 2005 06:10 Go to previous messageGo to next message
I see, sorry. Got them mixed up.
Its more about the twin injection that I'm interested in.
Re: Twin injection benefits? Sat, 17 September 2005 06:12 Go to previous messageGo to next message
what is twin injection and what do you want to know about it?
Dorio86
Bankstown
August 2005
Re: Twin injection benefits? Sat, 17 September 2005 06:14 Go to previous messageGo to next message
oldcorollas wrote on Sat, 17 September 2005 16:12
I want to no what twin injection is and why is it used, also what are the pros and cons.
Re: Twin injection benefits? Sat, 17 September 2005 06:23 Go to previous messageGo to next message
do you mean staged injection ( very popular with high power rotaries) where you have 2 banks of different sized injectors (so each inlet runner has size A & B injeector).
Allows you (with the right ECU) good control of fuel at low flow rates (e.g. idle - only using smaller injectors) and also at high flow (e.g. WoT under massive boost - both injectors in use at high duty rate) as you're not running injectors at close to 100% duty.
Downside is requiring an ECU to control two banks of injectors, the extra plumbing (usually 2 fuel pumps and two regulators to deal with the the massive flow you want at 100% power ouput), and the extra time to tune the ECU/engine for the complicated setup.
cheers, Charles.
Re: Twin injection benefits? Sat, 17 September 2005 06:34 Go to previous messageGo to next message
i think he's just trolling to get post count up. what he originally referred to is a diesel engine Rolling Eyes
clubagreenie
1st street on the right
Re: Twin injection benefits? Sat, 17 September 2005 06:47 Go to previous messageGo to next message
Is it ideal to have the injectors maxing out their cycle or should they be over sized to run at say max80%?
Re: Twin injection benefits? Sat, 17 September 2005 07:14 Go to previous messageGo to next message
clubagreenie wrote on Sat, 17 September 2005 16:47
80% is safe.. 90% might be.. depends on the opening and closing rates of the injector..
if duty is too high, then the injector may not fully close or become erratic in operation.. it also depends on how many injection events there are per engine cycle etc...
say it takes 2ms to open and close an injector. at 8000rpm, an engine cycle is 16ms.
1 injection event leaves 14ms for pulsewidth, and 12ms is 80% duty cycle (as measured conventionally) so you have 2ms to spare.
2 injection events means that you have 4ms of dead time, and 12ms of open time, ie 6ms per pulse... if you go above 6ms, the injector doesn't have time to open and close before next cycle.
so yeah, it depends on speed of injector (low impedance driven in peak and hold mode have faster opening times, but low imp with resistor is similar to high imp), and how many injection events.. each extra event per cycle reduces the allowable duty cycle due to the extra dead time needed for opening and closing...
aiui
Re: Twin injection benefits? Sat, 17 September 2005 07:19 Go to previous messageGo to next message
oh and the main reason (aiui) for havign stagd banks is the amount of fuel that si released by large injectors during their opening and closing time...
this amount cannot be changed as you can't reliably half or 3/4 open an injector...
and this amount of fuel may be too much for the engine at idle... and give poor idle fuel control due to the response to the tiny commanded pulsewidths.. (an injector fault, not ECU fault... most ECU'S have plenty of resolution, but injectors are not THAT precise when they are barely opening...)
Dorio86
Bankstown
August 2005
Re: Twin injection benefits? Sat, 17 September 2005 07:20 Go to previous messageGo to next message
oldcorollas wrote on Sat, 17 September 2005 16:34
NO.
If you have the money watch this dvd.
http://www.vividracing.com/catalog/images/bmrskyline.jpg
In the touge part, theres a ae86 coupe with twin injection running a 20v black top.
It doesn't say anything about, but the torque band was smooth all the way through the rev range.
gearb0x
Re: Twin injection benefits? Sat, 17 September 2005 07:37 Go to previous messageGo to next message
two injections are better than one
Laughing
Re: Twin injection benefits? Sat, 17 September 2005 08:01 Go to previous messageGo to next message
if i have the money Razz why not just hire from my local video store Razz
touge? LOL HAHHAHHAHA
last weekend i went driving on hokkaido touge... ie mountain roads Razz
i think you are missing the point.
twin injection, whatever that is, is not the reason..
you seem to be very confused Confused
[Updated on: Sat, 17 September 2005 08:08]
Re: Twin injection benefits? Sat, 17 September 2005 08:04 Go to previous messageGo to next message
oh and see that car in the bottom right corner??
i'm pretty sure i saw it (or a riced up version) the other day.. looked exactly the same and even had SOLBERG written on the rear windows..
at first i thougth it was just another riced up rex.. but i guess not Razz
Re: Twin injection benefits? Sat, 17 September 2005 08:10 Go to previous messageGo to next message
fuggit, i'm going to go down to sapporo station and see if it7s still there Razz
edit: fugger.. not there.... that'll teach me for not taking pics on the spur'o'the moment Wink
[Updated on: Sat, 17 September 2005 11:55]
river
Land of Oz
Re: Twin injection benefits? Sat, 17 September 2005 08:41 Go to previous messageGo to next message
Twin injection is just a way to try and get EFI to deliver as smoothly and as reliably as a good carb set-up. Smile
nyuk nyuk nyuk
seeyuzz
river
kingmick
Banned by his request
moved to tamworth
Re: Twin injection benefits? Sat, 17 September 2005 10:00 Go to previous messageGo to next message
river wrote on Sat, 17 September 2005 18:41
nyuk nyuk nyuk
seeyuzz
river
arse about me thinks!
you use twin injectors to a pot, to get the best spray pattern{atomisation} at the right rev range etc etc. there are a few reason to use them but it take alot of engine dyno work to make use of them!plus it saves using buckets with holes{1800cc each injector}like we did with the v6 2.3 engine,can anyone say fouling plugs down low!
mick
Dorio86
Bankstown
August 2005
Re: Twin injection benefits? Sat, 17 September 2005 11:45 Go to previous messageGo to next message
oldcorollas wrote on Sat, 17 September 2005 18:04
No, that's Dori's car, the car I'm talking about is a levin coupe build by garage motore which is also in the DVD.
I think it's this engine.
http://sky.zero.ad.jp/~zah65297/motore12.jpg
and that's the car
http://sky.zero.ad.jp/~zah65297/ebisu09.jpg
Re: Twin injection benefits? Sat, 17 September 2005 11:49 Go to previous messageGo to next message
Dorio86 wrote on Sat, 17 September 2005 21:45
acutally i was talking about the 2003 WRC RWX driven by Petta Solberg... as in that vid... and that i saw that car near my house last weekend...
but anyway...
so it has a second set of injectors.. big deal.... it's just a 20V Razz
Yian
Lwr Templestowe, Melbourne
Re: Twin injection benefits? Sat, 17 September 2005 12:04 Go to previous messageGo to next message
oldcorollas wrote on Sat, 17 September 2005 21:49
Ohhh... careful what you say Stewart-san. You will enrage the spoontah boys.
Dorio86
Bankstown
August 2005
Re: Twin injection benefits? Sat, 17 September 2005 12:10 Go to previous messageGo to next message
Nah, it's cool.
But it does seem like a good idea.
Re: Twin injection benefits? Sat, 17 September 2005 12:17 Go to previous messageGo to next message
It doesn't seem like such a great idea when you are running both injectors at high rpm/load and one dies causing a big time lean out on that cylinder resulting in a burnt piston.
Commonly done - can run smaller cheaper injectors rather than uber exxy big ones, might help with location of injector and spray, looks bling - but there are pitfalls.
Re: Twin injection benefits? Sat, 17 September 2005 12:33 Go to previous messageGo to next message
and since a 1.6L NA doesn't even use all that much fuel, there is no real advantage, except that ppl say "it was on a D1 dorifto car, it must be the best thing to do....
wings (on cars going sideways at low speeds Razz)
rivets
etc etc... it's all about the bling
or becuase there is a tendency to use shitty piggyback computers and extra injector controllers instead of using a standalone ECU...
spirokeet
London
Re: Twin injection benefits? Sat, 17 September 2005 12:41 Go to previous messageGo to next message
Quite a few motorbikes run 2 injectors per cylinder
Taken from Motor Cyclist article about the Honda CBR 600 RR:
There's one in the normal place downstream of the throttle plate that operates alone below 5500 rpm. Above that speed, a second injector, located above the bellmouth, comes into play, providing the fuel necessary for high-rpm power.
Race bikes have used this setup for years.
I remember reading somewhere that the second injector also provides the cylinder with fuel in a more combustion friendly manner, something about the size of the fuel droplets after being sucked down through the bellmouths.
Why bother though?
Re: Twin injection benefits? Sat, 17 September 2005 12:48 Go to previous messageGo to next message
spirokeet wrote on Sat, 17 September 2005 22:41
Why bother though?
bikes are difference as they actually have revs Razz
at idle and low rpm (ie 5500) they don't use as much fuel... but to get to 14000rpm, they have a much smaller window of injection in which to play with...
ie at 6000rpm, one engine cycle is 20ms.
at 14000rpm, each cycle is 8.6ms....
you need much bgger squirters to be able to get the fuel in during that time period.. not so many ppl even think about how much timethere si to inject, but for high revving motors (i consider 8000 to be about the start of that), you have to consider how long you have to play with...
also... for the higher rpm bikes the second injector is before the TB, like in most decent race car setups, so the fuel has time to atomise better before it gets to cylinder, and has better distribution.... safr to have a small injector below the TB so that you don't get fuel pooling etc from the big injector at idle...
on a car to be road driven?? why bother indeed Wink
but if you are aiming for 400 ponies from something under 2L, chances are your idle will suffer if you have just a big set of squirters..
as i said, it's just a 20V... even 300cc injectors are probably a bit too big Razz
emmac
Gippsland Lakes. Vic.
Re: Twin injection benefits? Sat, 17 September 2005 12:49 Go to previous messageGo to next message
Dorio86
The twin injectors per cylinder you ask about may refer to when one injector is mounted close to the valves & another injector is fitted to inject into the trumpet from further out. The basic reason for this is because the inner injector may provide more low down performance with the outer injector providing more top end. The ecu controls the "phase in" of the outer injector, as the engine revs. increase, to provide the switch over.This is something you would only consider on a serious racing engine.
emmac.
Dorio86
Bankstown
August 2005
Re: Twin injection benefits? Sat, 17 September 2005 12:50 Go to previous messageGo to next message
oldcorollas wrote on Sat, 17 September 2005 22:33
rivets
It's not a D1 car, it's not even a drift car has it runs soft suspension.
He's car, that was running twin injection Even Dori said when he was testing the car that the car had more horsepower than he's and feels even all the way through the rev range. What river said sounds right.
Now has anyone tried this because people's opinions doesn't really help. What people might think is right could be wrong.
I'm sick of people like the last dodgy mechanic that assumed that the grs gearbox is the same has the vr4.
Like "what's the point of running 5 valves per piston when 4 valves are fine?"
[Updated on: Sat, 17 September 2005 12:52]
Dorio86
Bankstown
August 2005
Re: Twin injection benefits? Sat, 17 September 2005 12:52 Go to previous messageGo to next message
thanks emmac. I'll do some research on it.
spirokeet
London
Re: Twin injection benefits? Sat, 17 September 2005 13:00 Go to previous messageGo to next message
Dorio86 wrote on Sat, 17 September 2005 13:50
four valves are fine, the increase in power from a 5 valve Toyota head is due more to the angle of the valves and shape of the chamber than the number of valves.
five valves actually has more disadvantages than it has advantages.
Dorio86 wrote on Sat, 17 September 2005 22:50
dude, this is bigger than D1.. and who the fuck is Dori.. and what does it have to do with how two sets of injectors are used>
your syntax is remarkably difficult to read.
"Dori said when he was testing the car that the car had more horsepower than he's and feels even all the way through the rev range"
ooh, it must be true cos soem guy can tell by the seat of his pants that is has more power than his (not HE'S ffs). what a load of crap.
yes people have tried it.. WHERE THEY NEEDED TO. ie bikes (from factory) and turbo Audis running 20-30psi of boost with a Megasquirt...
anyone who finds that their large injectors are too nig to provide good fuel for idle will use them.. thats it.
there is no "my mechanic said this and blah blah", there is a REASON they would be used, but it should be avoided unless it is NECESSARY.
and dont bring that 5 valve shit up again, you're just being a post whore, and don't really have any interest in this at all... if you did, you would have read the responses to this thread and understood why two injectors per cylinder would be used and would not still be asking.
OMG..... obviously you didn't realise that river was TAKING THE PISS
EFI will ALWAYS give better fuel amounts across the full range of an engines operation. carbs will always be limited at some point of the range.
shesh Razz
Dorio86
Bankstown
August 2005
Re: Twin injection benefits? Sat, 17 September 2005 13:03 Go to previous messageGo to next message
spirokeet wrote on Sat, 17 September 2005 23:00
That's what I mean. But you would be surprised of the amount people that have the wrong idea about that.
Dorio86
Bankstown
August 2005
Re: Twin injection benefits? Sat, 17 September 2005 13:05 Go to previous messageGo to next message
oldcorollas wrote on Sat, 17 September 2005 23:00
shesh Razz
Sorry, but arent you from Japan, you should no.
Anyway Dori, Keiichi Tsuchiya has in the drift king, the founder of drift
Rivets?? WTF
Im not being a post whore, 5 valve was just has an example.
Maybe river was taking the piss but according to Dori's comments he sounds righ, hey he just might be right.
[Updated on: Sat, 17 September 2005 13:09]
Yian
Re: Twin injection benefits? Sat, 17 September 2005 13:08 Go to previous messageGo to next message
KNOW
But yeah, welcome back Bubbles. We missed you...
spirokeet
London
Re: Twin injection benefits? Sat, 17 September 2005 13:09 Go to previous messageGo to next message
^ Laughing ^
Dorio86 wrote on Sat, 17 September 2005 23:05
I'm Australian (as most ppl who have ben around since BEFORE toymods came into existence would know), and i now live in japan..
and i couldn't give a flying kazoo about D1, because it's far too pretentious and is to car racing what synchronised swimming is to a 100m freestyle race.....
arent = aren't
no = know
has in the drift king = ????
Profit????
LOL, founder of dorfito Laughing Laughing people have been driving that way for decades....
you know D1 was just made up for TV sponsorship, and so that kiddies would buy more magazines????
Dorio86
Bankstown
August 2005
Re: Twin injection benefits? Sat, 17 September 2005 13:15 Go to previous messageGo to next message
oldcorollas wrote on Sat, 17 September 2005 23:09
arent = aren't
no = know
Profit????
Your the one asked me who he was. Know your saying that you don't care who he his. Rolling Eyes .
An again your starting put words in my mouth.
I'm not going to answer back to your ignorant comment's.
Dorio86
Bankstown
August 2005
Re: Twin injection benefits? Sat, 17 September 2005 13:17 Go to previous messageGo to next message
Yian wrote on Sat, 17 September 2005 23:08
KNOW
Can you stop calling me bubbles, that's starting to annoy me
Re: Twin injection benefits? Sat, 17 September 2005 13:19 Go to previous messageGo to next message
Dorio86 wrote on Sat, 17 September 2005 23:15
You're the one who asked me who he was. Know Now you're saying that you don't care who he his is. Rolling Eyes .
And again you're starting to put words in my mouth.
fixed for you.
Yian
Re: Twin injection benefits? Sat, 17 September 2005 13:21 Go to previous messageGo to next message
Dorio86 wrote on Sat, 17 September 2005 23:17
KNOW
I only called you Bubbles once. But to annoy you, Hey Bubbles!!oneone!!
Re: Twin injection benefits? Sat, 17 September 2005 13:26 Go to previous messageGo to next message
ok, getting back to the valves thing, sicne you wanted to go OT (was there a topic in the first place?? i thought it was twin jection in diesel engines.. but anyway..
as you should know, it is all about the effective "curtain" around the valves that can flow air.. there is not point having 6 valves if they are all shrouded so much that none of them can flow..
it can be shown mathematically that 4 valves is better than 2, but 5 better than 4?? compared to extra valve train weight, and extra valve shrouding??? it's a tough call...
in turbo applications, where flow is even more important in terms of the mass of air, 16 and 20V don't seem to be any different....
please respond with something at least a little bit technical...
Re: Twin injection benefits? Sat, 17 September 2005 13:49 Go to previous messageGo to next message
Dorio86: the correct term is staged injection - as mentioned in my original post to this thread - one smaller injector and one larger injector per inlet tract.
I've only ever seen this on cars with massive forced-induction systems - it appears to suit longer induction paths (like the inlet and TB for a turbo 20B in a drag car for example) than a short path like an 4AGE with ITBs
on the megasquirt forum (www.msefi.com - which oldcorollas and myself and other toymods users have lurked/got-involved for a few years now) there are a growing number of heavily-modified-engine users running multiple banks of injectors.
unless you were going to run your 4age with large amounts of boost (or something even sillier like convert to uber-low compression and race fuel and/or methanol) then i really can't see staged injection doing anything for you except have the ability to run massively rich, have less top-end power and coke up the head, zorst valves and zorst system prematurely.
cheers, charles.
STR8 2.8
Re: Twin injection benefits? Sat, 17 September 2005 14:13 Go to previous messageGo to next message
for fucks sake. i think you should be banned for a complete lack of spelling ability.
spirokeet
London
Re: Twin injection benefits? Sat, 17 September 2005 14:19 Go to previous messageGo to next message
Bubbles bought a Haynes manual
Smile
ed_ma61
Lost in the K hole
Re: Twin injection benefits? Sat, 17 September 2005 15:10 Go to previous message
enough junk
thread locked
ask this question again in a new thread, with a more specific focus, if you require further clarification.
As to whether this is bubbles or not, that will be looked into
ed
Previous Topic:4K-C!!
Next Topic:t51r or similar.
Current Time: Tue Nov 3 14:37:50 UTC 2026
Total time taken to generate the page: 0.14800214767456 seconds
