Toymods » Tech & Conversions » ga70 BRAKES
ROBBO_ma61
ga70 BRAKES Thu, 02 January 2003 03:08 Go to next message
does anybody know if GA70 brakes will fit on a ma61?
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon13.gif  Re: ga70 BRAKES Thu, 02 January 2003 03:19 Go to previous messageGo to next message
Not without a lot of work. If at all....
ROBBO_ma61
Re: ga70 BRAKES Thu, 02 January 2003 03:20 Go to previous messageGo to next message
fuck....any idea which brakes would be a best upgrade?
Re: ga70 BRAKES Thu, 02 January 2003 03:22 Go to previous messageGo to next message
All custom dude is the final answer. Don't mean to be mean, but search this one....it really has been done to death.
ROBBO_ma61
Re: ga70 BRAKES Thu, 02 January 2003 03:25 Go to previous messageGo to next message
what do you mean "search this one..its been done to death"?? Would anything off them fit as an upgrade...people are using bloody 2jz aristo brakes on an ma61...calipers etc.
Re: ga70 BRAKES Thu, 02 January 2003 03:27 Go to previous messageGo to next message
Sorry, I should have made it a bit clearer....this has been discussed to death....nothing really goes on easily.
ROBBO_ma61
Re: ga70 BRAKES Thu, 02 January 2003 03:28 Go to previous messageGo to next message
oh ok...any idea which would be the easiest and cheapest??...obviously not custom cost wise.
Re: ga70 BRAKES Thu, 02 January 2003 03:33 Go to previous messageGo to next message
You potentially could use those GA70s but it would need a lot of work. Talk to your engineer and see what he wants you to do....GA70 rotors are 280mm (or so), and 302 Falcons had 287mm rotors...he may stipulate that the brake diameter is at least that.
ROBBO_ma61
Re: ga70 BRAKES Thu, 02 January 2003 03:38 Go to previous messageGo to next message
rightio...thanks for that. keeping toyota brakes on another supra would be preferable..ill find out what is best...either from my engineer or from someone whos done a similar convo onto a ma61, if they all seem the same amount of trouble i will take what i can get at the right price :)Brakewise its probably the most important part of the convo...stiff bickies if you cant stop the car...so ill have to do it properly. Mk3 turbo supras would seem the easiest conversions but then again i may be wrong!! DId ma70 use same brakes as jza70 and ga70?
Re: ga70 BRAKES Thu, 02 January 2003 03:57 Go to previous messageGo to next message
MA70 is a bit bigger....300mm front rotors. GA70 rotors are almost identical to earlyish Tarago rotors.
Re: ga70 BRAKES Thu, 02 January 2003 11:06 Go to previous messageGo to next message
The unfortunate problem is that the later model Supras had setups that aren't even remotely like the Mk2. I've asked this question before, do a search on that.
suprav8
melbourne
Re: ga70 BRAKES Thu, 02 January 2003 11:21 Go to previous messageGo to next message
Your engineer won`t ask you to put on bigger brakes.As long as the standard 1`s are in top order!
Re: ga70 BRAKES Thu, 02 January 2003 11:30 Go to previous messageGo to next message
Yeah people have registered 1JZGTE Supras with standard brakes. Just make sure they work perfectly...which is my next task Sad
ROBBO_ma61
Re: ga70 BRAKES Thu, 02 January 2003 11:35 Go to previous messageGo to next message
really? Nice...as long as i can stop the thing...how much are the brakes worth for a pair? How much should i be paying for them if i am asked to change them...surely ga70 would do? Thats bigger and better than an ma61 arent they? Frank ive spoken to you before, Im in brisbane, i was going to do a 1jz conversion.I found two 1jzs for $400 complete with parts...both were fuckt in the bottom end...spun big end bearings..ive looked around to no real avail so i Changed my mind when i found a 302 done up going very cheap and having someone to help me install it at no cost...good enough reason for me to get it!!
suprav8
melbourne
Re: ga70 BRAKES Thu, 02 January 2003 11:53 Go to previous messageGo to next message
dude...forget about the GA70 brakes!!....it`s just not going to happen!...your standard brakes are more than capable!
Re: ga70 BRAKES Thu, 02 January 2003 22:44 Go to previous messageGo to next message
Speak to an engineer before you do anything. Chances are you won't be required to touch your brakes at all. I consulted an engineer before I started my project, and he said my existing brakes are fine.
ROBBO_ma61
Re: ga70 BRAKES Fri, 03 January 2003 00:14 Go to previous messageGo to next message
SWeeet...saves me some cash $... Very Happy
rob_RA40
c'town, NSW
Re: ga70 BRAKES Fri, 03 January 2003 00:59 Go to previous message
check this site out if u want to do a 5 stud conversion with your MA61
http://www4.tpgi.com.au/users/loats/
Previous Topic:another indicator Q?
Next Topic:Help - Removal of Chrome strips
Current Time: Fri Nov 20 06:59:47 UTC 2026
Total time taken to generate the page: 0.0075759887695312 seconds
