Toymods » Tech & Conversions » 4AGE idle and cold-start problem
BootySlap
4AGE idle and cold-start problem Sat, 17 September 2005 23:31 Go to next message
First problem is on cold start it takes my 4AGE a good 20 seconds of hard cranking before it turns over.
Secondly, when cold, it idles at around 1800rpm and falls back to about 1300rpm when warm.
If I adjust the idle screw so that warm idle is around 900rpm, if I turn the ignition off and start the car again it will turn on for about 5 seconds and the idle will drop until the car dies.
Any ideas ? I am thinking cold-start injector and idle-up system im not sure how to check these or what else it could be ?
kingmick
Banned by his request
moved to tamworth
Re: 4AGE idle and cold-start problem Sun, 18 September 2005 11:02 Go to previous messageGo to next message
standard puter? you might have a vacuum leak and or no cold start injector working.
BootySlap
Re: 4AGE idle and cold-start problem Sun, 18 September 2005 11:06 Go to previous messageGo to next message
Yea standard everything. Ill have a look around some lines to see if I can find a vacuum leak thanks.
To check cold start injector should I take it out still connected to the fuel line and connect it directly to the battery terminals and spray into a bottle or something?
sideshow
Re: 4AGE idle and cold-start problem Sun, 18 September 2005 11:31 Go to previous messageGo to next message
yer while yr at it make some small sparks with the battery and wiring and see the fuel catch on fire hehe
cold start injector onlyworks when crankin a cold engine
so disconnect the wiring to it see if it makes a difference
BootySlap
Re: 4AGE idle and cold-start problem Sun, 18 September 2005 11:43 Go to previous messageGo to next message
ok point taken hehe. ill check it out thanks.
kingmick
moved to tamworth
Re: 4AGE idle and cold-start problem Mon, 19 September 2005 02:14 Go to previous message
lol you beat me to it sideshow!
mick
Previous Topic:What is the smallest profile available in 14" tyres?
Next Topic:50,000km service
Current Time: Fri Nov 20 20:17:46 UTC 2026
Total time taken to generate the page: 0.0065431594848633 seconds
