Toymods » Tech & Conversions » 50,000km service
Big Rob
March 2005
50,000km service Sun, 18 September 2005 02:39 Go to next message
Hey everone,
I bought my GZ20-L soarer a few months ago with just under 42000km. Now i have done just over 50,000 and need to service the car. Is there anything special needed to be done at 50,000 like a major service at 100,000. Also if possible could you post part numbers with you recomondations on what i need to do.
Thanks guys,
Rob
Stretch
Sydney,Hurstville
Re: 50,000km service Sun, 18 September 2005 06:13 Go to previous messageGo to next message
should just be a straight forward service,
i.e replace engine oil
replace engine oil filter
check brake pads
check for any oil leaks
check steering and suspension components
check tyre pressures
check all fluid levels
check tyres if they need replacement or balance or a wheel alignment
thats pretty much all i can think of off the top of my head. i dont know the part number for this car.
Re: 50,000km service Sun, 18 September 2005 07:24 Go to previous messageGo to next message
yar, my car recently had it's 50,000km service done in japan.. just changed oil and oil filter, and checked levels of everything else.. no big deal.
sparkies are around 100Kkm (if they are Pt or Ir) and timing belt and such, but 50K is just a look see..
you miht want to change brake and clutch fluid.. they seem to never get changed...
FWDCelica
sydney,nsw.oz.
Re: 50,000km service Mon, 19 September 2005 00:20 Go to previous messageGo to next message
oldcorollas wrote on Sun, 18 September 2005 17:24
Yeah Brake Fluid and Radiator Coolant should be changed every 2 years regardless of mileage according to Owners Manual.
Big Rob
March 2005
Re: 50,000km service Mon, 19 September 2005 02:12 Go to previous message
ok, thanks for your replies. Just thought that it may have been an important number. I'm pretty good on brake pads and all fluids as such. The car was only complied a few months ago where everything like that was changed.
So i guess i'll just be doing the basics cause if it aint broke dont fix it!
This is the best info what i found out on the soarer for filter part numbers and such:
http://members.optusnet.com.au/mkhala/red_celica/1 G-GTE_info/
See you guys later!
Previous Topic:4AGE idle and cold-start problem
Next Topic:ST184 2001 Celica sx rims will fit?
Current Time: Fri Nov 20 20:02:21 UTC 2026
Total time taken to generate the page: 0.0087699890136719 seconds
