Toymods » Tech & Conversions » need help.
Touge 86
Endeavour Hills
September 2005
need help. Sun, 18 September 2005 07:03 Go to next message
Just punched a gutter and diff moved across anyone know whats up n probably how much a new diff and axles will cost me????
Rex_Kelway
Re: need help. Sun, 18 September 2005 07:12 Go to previous messageGo to next message
Let Rex guess, you aren't as good at drifting as you thought.
As for the damage:
Unfortunately whats happened is the whole rear section of the chassis has been bent out of square meaning that it will either have to go in for major structural straightening or have the parts swapped into a new shell.
It will definately not be a matter of panhard rod and/or bracket.
A stock Sprinter S-diff is worth about $550 and axles are usually $375 each.
Touge 86
Endeavour Hills
September 2005
Re: need help. Sun, 18 September 2005 07:15 Go to previous messageGo to next message
but the diff housing is still in the middle but the passenger side wheel is pushed in and the othe is out so could it just be the axles???
Re: need help. Sun, 18 September 2005 07:34 Go to previous message
Touge 86 wrote on Sun, 18 September 2005 17:15
ooh that sounds baaaaaad. so you hit so hard you smashed the diff centre??? ooops. and chances are it's still bent.. esp if you hit THAT hard Sad
refer to Rex's prices....
Previous Topic:4agze ecu and injectors on NA setup?
Next Topic:intercooler bits
Current Time: Thu Nov 19 17:14:19 UTC 2026
Total time taken to generate the page: 0.0053989887237549 seconds
