Toymods » Tech & Conversions » Hid beam help!!
shezza
Melbourne, Victoria
March 2005
Hid beam help!! Sun, 18 September 2005 09:06 Go to next message
Well I just changed my casing after I lost it in a little ding I had (as seen is the following topic: http://forums.toymods.org.au/index.php?t=msg&t h=80799&start=0&rid=10007&S=0df826463e d08c77763c379b0b9f37b2 and Im not sure if the globe was affected by the ding but that globe gives a spread beam and the untouched one gives a very focused beam. Im quite sure its supposed to be focused, anyone know what is causing it to be spread?
Spread
http://i2.photobucket.com/albums/y45/shezza84/spread.jpg
Focused
http://i2.photobucket.com/albums/y45/shezza84/focused.jpg
kingmick
Banned by his request
moved to tamworth
Re: Hid beam help!! Sun, 18 September 2005 10:52 Go to previous messageGo to next message
check to see the globe is still held in its right place.then make sure the inside hasnt had the dust spread inside the lens from the ding.can also be low voltage etc or the light is way out of alignment.
shezza
Melbourne, Victoria
March 2005
Re: Hid beam help!! Sun, 18 September 2005 12:14 Go to previous messageGo to next message
kingmick wrote on Sun, 18 September 2005 20:52
The globe is still in its place. I have a aftermarket brand new lens could it be caus it has a shitty reflector?
So u think maybe I should switch sides and see what happens (left to right and right to left)?
Btw I just realised the globe that is giving me the shitty spread of light is the one on the other side and not the one that had the ding Confused
[Updated on: Sun, 18 September 2005 12:15]
mynameisrodney
Kellyville, Sydney
Re: Hid beam help!! Sun, 18 September 2005 13:15 Go to previous messageGo to next message
it was probably always shitty then, but you just didnt realise coz they both were. now you have it in with a new one so it stands out. replace it and you should be fine.
chris
shezza
Melbourne, Victoria
March 2005
Re: Hid beam help!! Sun, 18 September 2005 13:17 Go to previous messageGo to next message
No, they used to be both focused beams. The only thing I changed was the headlight not the bulb
mynameisrodney
Kellyville, Sydney
Re: Hid beam help!! Mon, 19 September 2005 00:03 Go to previous messageGo to next message
shezza wrote on Sun, 18 September 2005 22:14
what did you change on this side of the car then?
FWDCelica
sydney,nsw.oz.
Re: Hid beam help!! Mon, 19 September 2005 00:07 Go to previous messageGo to next message
shezza wrote on Sun, 18 September 2005 19:06
HID globes are only to be used with projector lenses.
Therefore the new lense is not the right 1.
What type of car is it ?
kingmick
moved to tamworth
Re: Hid beam help!! Mon, 19 September 2005 02:10 Go to previous messageGo to next message
youll fine its the lens. if its at the right alignment,then then new lens isnt as good as the old.
mick
shezza
Melbourne, Victoria
March 2005
Re: Hid beam help!! Mon, 19 September 2005 09:40 Go to previous messageGo to next message
mynameisrodney wrote on Mon, 19 September 2005 10:03
I changed my quater panel and the headlight and parking lens. But you guys are probably right. Shitty reflector Sad
Craaaap
THx all Smile
shezza
Melbourne, Victoria
March 2005
Re: Hid beam help!! Wed, 28 September 2005 11:17 Go to previous message
Got a set of gx81 headies and its better but still not perfect like it was before. Maybe its the way I put the sheilding back on ... I dunno.
I might have to buy a new globe ($250) Crying or Very Sad
Also, the same globe often goes out when I use high beam (when I use high beam the globe is pulled back) Anyone know why this might be happening?
Previous Topic:TA63 GT, does it have a W55??
Next Topic:ta22 rotor conversion
Current Time: Thu Oct 22 06:58:14 UTC 2026
Total time taken to generate the page: 0.017972946166992 seconds
