Toymods » Tech & Conversions » SC14 - what oil? and other questions
redzed
April 2005
SC14 - what oil? and other questions Mon, 19 September 2005 04:00 Go to next message
i have a sc-14 suck thru carbie setup on my torana. ive noticed the inside of the pipe off the charger has a thin black film of oil over it. i did a search and its got somthing do do with the "breather" hoses on the blower ventilating it. thats my next question, the blower has i think 4 of these hose fittings. what are they for? at the moment i have them pluged up as they were leaning out the fuel mixture. is this ok to block up?
i checked the oil, it was abit low, about 120mls came out. what non-genuine oil can i use to replace it? i have some castrol 10w40 gear oil that is quite thin. ive heard the mobile 1 5w/40 is the go. will this castrol 10w/40 be ok?
btw, its been overdriven to about 78%, approx 10psi
[Updated on: Mon, 19 September 2005 04:10]
4agte
Toronto, Downtown
Re: SC14 - what oil? and other questions Mon, 19 September 2005 06:17 Go to previous messageGo to next message
any reasonably thin synthetic oil will do really i use fuchs 0w-20 but alot of people use mobil one which is no problem at all as for the rest of it i have nfi
toof
Re: SC14 - what oil? and other questions Mon, 19 September 2005 09:04 Go to previous messageGo to next message
im running the mobil 1 5/30 in mine and have had no greif and i know a few doing the same.
id pick either a 5 or 0 weight oil.
as far as the breather hoses they need to be hooked up to vent the crank case in the charger.
i couldnt however tell you off hand of the connections required.
drift86levin
brisvegas
Re: SC14 - what oil? and other questions Mon, 19 September 2005 11:14 Go to previous messageGo to next message
i used some GM supercharger Gear oil..available at any holden dealership for about $14 a bottle (120ml)..just to be on the safe side Smile
Matty
redzed
April 2005
Re: SC14 - what oil? and other questions Mon, 19 September 2005 11:39 Go to previous messageGo to next message
well ive sorted out the oil issue.
only thing i still need to know is what to do with these "breather" hoses.
can anybody shed some light of what they are exactly used for and which ones....
Henn
Rosanna, Melb
Re: SC14 - what oil? and other questions Mon, 19 September 2005 14:02 Go to previous message
From the factory, the breather tubes are set up in some way through VSVs to minimise the pressure across the SC end seals. This means that less oil is sucked through while the manifold is at vacuum. I'm not sure exactly how they control it or where the VSV is connected, though a good Google may shed some light (I remember reading up on it once).
However you can just bridge all the breathers together. I've run an SC12 like that for about 2 years without problem.
Hen
Previous Topic:2TGEU + T50 into a AE85
Next Topic:jzx81 to MX83 power steering rack
Current Time: Thu Nov 19 10:24:38 UTC 2026
Total time taken to generate the page: 0.007249116897583 seconds
