Toymods » Tech & Conversions » fuel pressure
4agzebuggy
Penrith
icon9.gif  fuel pressure Thu, 02 January 2003 05:52 Go to next message
How much fuel pressure do you need to run a 4agze with 12 psi boost ??
It started to play up under full acceleration. so we crimped the return line to the fuel tank and it ran perfect under load but it would not idle.
so I'm not sure if its the fuel pump or the fuel regulator.
At idle the fuel pressure is 30 psi and 40 psi when you accelerate.
kevin
SUPRAGTE
North Sydney
Re: fuel pressure Thu, 02 January 2003 06:09 Go to previous message
That seems reasonable. For every psi of manifold pressure the rail pressure should rise 1psi and your is doing that so its fine. The idle(vacuum) fuel pressure seems a little low but that maybe what gze's run stock.
Less pressure is need for good atomisation when the manifold is in vacuum cause the suction helps fuel distribution and atomisation.
Previous Topic:unleaded filler neck on pre-unleaded car....HOW?
Next Topic:PU bushes&After Marker Performance parts
Current Time: Mon Oct 26 13:29:07 UTC 2026
Total time taken to generate the page: 0.0041310787200928 seconds
