Toymods » Tech & Conversions » 2T Block with 2TG head??
BigBadBenny
Brisbane, Queensland
2T Block with 2TG head?? Wed, 05 June 2002 09:27 Go to next message
I've recently come into contact pretty much a 2tg engine minus the block, as well as an imaculate rear bumper brand new that has never been fitted to a celica. The Yamaha head is still wrapped in plastic, but enough boasting from me.
Underneigh my house I have a 2T block that I was hopefully going to use with the 2TG parts, but I'm told that a few minor changes need to be made to the lube system. These changes to be done is the part that I'm not sure.
Can anyone help me in giving a little bit of advise??
I hope to turn it into a tough NA 2TG to give those 4AGE boys a go.
any help would be great.
Benny
TA22-3SGTE
MACKAY
Re: 2T Block with 2TG head?? Wed, 05 June 2002 13:14 Go to previous messageGo to next message
Benny
The 2TG and 2T blocks are the same , all you need to do is to block off the cam bearing oil holes in the cam tunnel behind the short idle shaft , they usualy have plugs like welsh plugs to press in the cam tunnel to seal the holes but if get the cam bearings knocked out and knocked back in with the oil holes misalined this will seal these oil holes .
( you must also use 2TG pistons )
Trevor
thetoyman75
Club President
Re: 2T Block with 2TG head?? Wed, 05 June 2002 22:25 Go to previous messageGo to next message
Benny,
Mate sounds like a really good find.
If its just the head assembly keep in mind you will need the timing chain covers etc from a 2TG. You will also need the Half cam as opposed to the full cam found in the 2T.
Trevor has your oil question covered Smile
Hope that helps,
BigBadBenny
Re: 2T Block with 2TG head?? Thu, 06 June 2002 08:13 Go to previous message
thanks for the help.
I've got all the rest of the 2TG gear. it's just the bock that is missing. I was aware that I need 2TG pistons,,, but I'm thinking going over sized forgies for it.
and getting some lumpy cams and double valve springs, the whole deal.
Hmmmm but before all of this can take place I need to sell my BMW
Anyone want one for $8000 it's very shimcko.
Benny
Previous Topic:Seatbelts - URGENT
Next Topic:wiring and insanity, both go hand in hand
Current Time: Thu Nov 19 18:48:28 UTC 2026
Total time taken to generate the page: 0.0057370662689209 seconds
