Toymods » Tech & Conversions » Brakes
NeDiC
March 2005
Brakes Mon, 19 September 2005 23:08 Go to next message
I've just had my brakes upgraded to commodore discs at the front and have had a commodore diff put in with commodore disk in the rear, what will be a good brake booster to use, i shoud also mention my standard booster is alot bigger then a standard ke30's, apparently the 78 model ke30s came out with a bigger booster,
any help would be good
illuminatus
eastern suburbs, melbourne
March 2005
Re: Brakes Mon, 19 September 2005 23:10 Go to previous messageGo to next message
hmmmm why not get a commodore booster?
NeDiC
March 2005
Re: Brakes Mon, 19 September 2005 23:15 Go to previous messageGo to next message
i thought that there might be something that fits alot easier, just checking my options
Henn
Rosanna, Melb
Re: Brakes Mon, 19 September 2005 23:43 Go to previous messageGo to next message
Are you sure you need to upgrade your booster? If you have bigger brake pistons then a bigger master cylinder is needed, but the original booster could well be kept. May save you some hassle.
Hen
Celica_John
Re: Brakes Mon, 19 September 2005 23:55 Go to previous messageGo to next message
my mate did the same thing and is using a nissan silvia booster on his ke35.
bolts straight on.
he probaby has a spare as well
pm me if you're interested
Re: Brakes Tue, 20 September 2005 00:00 Go to previous messageGo to next message
AMI built KE30/50 have a PBR booster. You will find that the Commodore master cylinder will bolt straight up to the PBR booster. I used a KE30 PBR booster with VN Commodore master cylinder in my Crown. You will need to make some new lines to the front brakes - twin outlet compare to single.
NeDiC
March 2005
Re: Brakes Tue, 20 September 2005 05:28 Go to previous message
sorry guys i meant to say master cylinder not booster
thanks for the replies
Previous Topic:best place for boost?
Next Topic:GX81 Digital Dash
Current Time: Sun Aug 9 18:12:59 UTC 2026
Total time taken to generate the page: 0.008634090423584 seconds
