Toymods » Tech & Conversions » TA22 diff ratio?
Evan
TA22 diff ratio? Tue, 20 September 2005 09:39 Go to next message
I have a ta22 diff.
I think they are 4.1 ratio?
I want to put this in my t18 diff.
Will this work?
Any help would be great
Evan
Dale_ta22
Forster NSW
Re: TA22 diff ratio? Tue, 20 September 2005 09:41 Go to previous messageGo to next message
If it's a T series diff it will be a 4.1.
Evan
Re: TA22 diff ratio? Tue, 20 September 2005 10:54 Go to previous messageGo to next message
oh ok.
I think my T18 diff is a 3.9?
or higher ratio
EldarO
Perth, WA
Re: TA22 diff ratio? Tue, 20 September 2005 17:02 Go to previous messageGo to next message
T-18's are usually 3.9, ta22's are usually 4.1, the trans code on the celica for 4.1 is T292 or something similar.
the celica centre will fit your t-18 diff.
Eldar.O.
Evan
Re: TA22 diff ratio? Tue, 20 September 2005 23:14 Go to previous messageGo to next message
Nice,
Thank you guys
Very Happy
Re: TA22 diff ratio? Tue, 20 September 2005 23:17 Go to previous messageGo to next message
TA22 manual: 4.1:1
TA22 auto: 3.9:1
Henn
Rosanna, Melb
Re: TA22 diff ratio? Wed, 21 September 2005 01:52 Go to previous messageGo to next message
As you can see from above it's either 3.9 or 4.1
Easiest way to tell is to either count teeth, or if the centre is in a housing then count turns of the tailshaft for one turn of an axle.
Hen
Re: TA22 diff ratio? Wed, 21 September 2005 02:53 Go to previous messageGo to next message
I should probably add that not all TA22's have a T series diff. The early ones (I think pre 73?) came with a D series.
September_Squall
Melbourne, Australia
March 2005
Re: TA22 diff ratio? Wed, 21 September 2005 04:55 Go to previous message
FYI TA23 with automatic transmission had the option of 4.3.
It's rare as hens teeth as to get it the original buyer had to select the 1600 over the 2L (TA23 over RA23), then select the auto over the manual, then select the 4.3 in preference to the 4.1.
As if you would choose the 'optional' shorter ratio instead of the 'standard' 4.1 if you'd already chosen the small engine and the automatic ~ in a Celica!
Previous Topic:Carburettors vs EFI
Next Topic:7M-GZE, what power figure
Current Time: Sun Oct 18 20:04:51 UTC 2026
Total time taken to generate the page: 0.0055990219116211 seconds
