Toymods » Tech & Conversions » Strange coil voltage readings at ignition coil ?
stevenvandecauter
Belgium
Strange coil voltage readings at ignition coil ? Tue, 20 September 2005 13:43 Go to next message
A)
Before cranking, with key in 'ON' position, I got a reading of :
6,6 Volts
B) After cranking, engine running :
9,8 Volts
C) Without the ballast resistor, this would have been:
13,5 Volts
I find it strange that the voltage at the coil in the 'ON' position is only a bit more than 6 Volts ?
I would expect the same voltage reading than when the engine is running (9,8 Volts).
Is there something wrong here ? Can somebody explain what is happening here, please ? I'm confused . . .
M.W.P.
Rocky Mountains, Canada
Re: Strange coil voltage readings at ignition coil ? Tue, 20 September 2005 15:45 Go to previous messageGo to next message
Whats the voltage while cranking?
Could the higher running volatge because caused by the flyback perhaps?
[Updated on: Tue, 20 September 2005 15:57]
stevenvandecauter
Belgium
Re: Strange coil voltage readings at ignition coil ? Tue, 20 September 2005 15:56 Go to previous messageGo to next message
Well, I didn't check that as I cannot crank the engine over and do a reading at the same time, the digital meter has no clamps to put on the coil.
But I guess when starting the ballast resistor is bypassed, giving the coil about 10 to 12 volts (taking the drain from the starter into account).
Re: Strange coil voltage readings at ignition coil ? Tue, 20 September 2005 15:59 Go to previous message
stevenvandecauter wrote on Tue, 20 September 2005 23:43
A)
6,6 Volts
9,8 Volts
13,5 Volts
4-5V drop of ballast resistor,
11.5V battery,
14.5 or so with alternator... sounds about right...
what abouton the other side of the ballast resistor??
Previous Topic:SC12 & SC14 actual boost levels?
Next Topic:A/C wiring gremlins
Current Time: Sat Nov 21 07:14:28 UTC 2026
Total time taken to generate the page: 0.0059289932250977 seconds
