Toymods » Tech & Conversions » Carburettors vs EFI
Switch to threaded view of this topic Create a new topic
Dorio86
Bankstown
August 2005
Carburettors vs EFI Tue, 20 September 2005 23:32 Go to next message
Arrgh, my back hurts. I don't no how they can sleep, and not a chair insight.
Learning more about twin injection, there wasn't much of a point to run it. You have to run 2ECU's and all it really does it just makes the car little bit more responsive and cools the engine down better. For the cost its not worth it and there isn't much to gain.
Anyway, to the topic of the thread, carburettors have chokes and jets in the air-stream which limits peak airflow, so I don't think it will outperform a good injection system.
I would like to know peoples experiences instead of opinions and what they think.
[Updated on: Tue, 20 September 2005 23:34]
ehendrikd
ballarat
Re: Carburettors vs EFI Tue, 20 September 2005 23:43 Go to previous messageGo to next message
search is your friend
http://forums.toymods.org.au/index.php?t=msg&t h=5062&rid=2577&S=0d868fc5d438454bec1102ee e3080b38
Dorio86
Bankstown
August 2005
Re: Carburettors vs EFI Tue, 20 September 2005 23:49 Go to previous messageGo to next message
Thanks .
Skip
Re: Carburettors vs EFI Wed, 21 September 2005 00:41 Go to previous messageGo to next message
Dorio86 wrote on Wed, 21 September 2005 07:32
no problem just remove the choke Smile
ke382TG
Re: Carburettors vs EFI Wed, 21 September 2005 00:43 Go to previous messageGo to next message
Confused
Anyway, you obvisouly didn't do that much research if one of your conclusions is this:
I know of a particular car that I see regularly that is setup for staged injection and runs one ECU. I think I can safely assume your two ECU info came form some Jap website where the car had a zillion electronic devices all doing the job one decent ECU could handle.
Oh dear, probably not much point in some instances and probably quite practical in other instances. I don't think you actually learnt much at all.
Please define "performance" are you referring to peak power, driveability, economy etc???
Here are some of my EXPERIENCES:
Living in a place that sees sub zero temps meant that my car with twin 40mm sidedraft carbies was a farken pain to drive until properly warmed up. They needed regular tuning, offered average fuel economy, had adequate top end, sounded tough.
My EFI on the same capacity engine shites all over it in every respect except induction noise.
Carbies are old school and fitting them to something now is only done to keep the car setup like it was back in its day, for the sake of being different (eg carbs on a 4AG), the owner is scared of technology or they were fitted because they were laying around the shed.
Dorio86
Bankstown
August 2005
Re: Carburettors vs EFI Wed, 21 September 2005 00:47 Go to previous messageGo to next message
Refer to the twin injection thread which is blocked. Check the last 6 posts.
Installing two injectors per cylinder can require two ecu's.
ke382TG
Re: Carburettors vs EFI Wed, 21 September 2005 00:52 Go to previous messageGo to next message
No one is disputing that you can or could but you said:
That was what I was pointing out. Smile
Looking at what a lot of Japanese folk do to their cars highlights what can or could be done but it does not make it the best or only way to do something Wink
Re: Carburettors vs EFI Wed, 21 September 2005 00:53 Go to previous messageGo to next message
Dorio86 wrote on Wed, 21 September 2005 08:47
Refer to ke382TG's post.
Any DECENT ecu can run staged injectors.
ie, a second set of injectors turning on when you like.
Rotors run them stock.
You saw the 2 ecu thing, because ppl in japan don't used decent ecu's.
They use piggypack ontop of piggyback ontop of piggyback.
Dorio86
Bankstown
August 2005
Re: Carburettors vs EFI Wed, 21 September 2005 01:06 Go to previous messageGo to next message
But these aren't staged.
Re: Carburettors vs EFI Wed, 21 September 2005 01:08 Go to previous messageGo to next message
Dorio86 wrote on Wed, 21 September 2005 09:06
So you set the 2nd stage to come on at 500rpm instead of 3500rpm
It doesn't matter.
Re: Carburettors vs EFI Wed, 21 September 2005 01:09 Go to previous messageGo to next message
What are they then dude? Rolling Eyes
ke382TG
Re: Carburettors vs EFI Wed, 21 September 2005 01:13 Go to previous messageGo to next message
That changes nothing in this discussion, 2 ECUS are not required to run 2 banks of injectors whether they are run simultaneously or staged.
How's the weather in Japan Wink
I found your "reference" and this dude clearly has done this just for pose/wank factor. 180ps is nothing great and does not require twin injectors nor 2 ECU's.
http://img355.imageshack.us/img355/7563/pdvd0014lu.png
Corona RT142
Campbelltown
Re: Carburettors vs EFI Wed, 21 September 2005 01:16 Go to previous messageGo to next message
Then whats the point of it then, ie by staging them you have smaller injectors that deliver a more accurate flow at low rpm in an attempt to not have huge fuel consumption, then when needed the second set of injectors chime in and add the extra fuel needed.
By not having the staged you may as well have one big set of fuck off injectors as you are just complicating matters.
Another thing to note on the twin injection drift car is it states that the transmission is only a TRD 3 speed i mean wtf.
-=DV=-
Newcastle, NSW
Re: Carburettors vs EFI Wed, 21 September 2005 01:23 Go to previous messageGo to next message
http://www.thex12.com/ctech/uploads/-=dv=-/8531.jpg
so this will be the 4th thread on the same subject started by this guy that has been locked in 3 days...mate ur going to get urself banned from the tech secion if u cant just FUCKING DROP IT!
ke382TG
Re: Carburettors vs EFI Wed, 21 September 2005 01:25 Go to previous messageGo to next message
Here is another "reference" to the twin injection setup, very interesting:
http://img357.imageshack.us/img357/3305/dumbozzie1oy.png
Corona RT142
Campbelltown
Re: Carburettors vs EFI Wed, 21 September 2005 01:29 Go to previous messageGo to next message
Lol my main concern is the guys face sheesh did somebody say pull my finger Razz . Second how the fuck is he running a full original exhaust on what looks to be a 20v black top in RWD setup when they came FWD only.
[Updated on: Wed, 21 September 2005 01:29]
Dorio86
Bankstown
August 2005
Re: Carburettors vs EFI Wed, 21 September 2005 01:39 Go to previous messageGo to next message
DV: Drop what, I'm not trying to make a point. And try to read all the posts instead of one.
Ke382TG: The weather is nice and sunny. I'm going to Tokyo tomorrow!
"ToyMods provides a friendly environment for Toyota owners and enthusiasts in which they can learn how to modify their car and improve their automotive skills. Flame suit required"
Anyway I have read the old thread. EFI rules.
corona: I think thats the name of the exhaust.
And the trd 3 gears, use some common sense, just a little.
SEXY 16
ghetto area 2745
Re: Carburettors vs EFI Wed, 21 September 2005 02:52 Go to previous messageGo to next message
the wheels on the bus go round and round, round and round , round and round, the wheels on the bus go round and round all day long Razz
river
Land of Oz
Re: Carburettors vs EFI Wed, 21 September 2005 02:56 Go to previous messageGo to next message
Dorio86 wrote on Wed, 21 September 2005 11:39
Rubbish!
seeyuzz
river
Re: Carburettors vs EFI Wed, 21 September 2005 03:30 Go to previous messageGo to next message
having owned:
carbi (RA23 & GC galant & motorbike)
forced induction carbi (RA40 18RCT)
EFI (MA61)
.. and have driven numerous other vehicles (i'm over 35, so i think nearly 20 years of drivingcounts for something)
In my experience EFI is the best for reliability, power, fuel use and maintenance overheads.
Tunability only comes with aftermarket ECUs (which my humble RA40 is getting) will cover the remaining gap.
As for the twin-ECU bullshit?! - what kind of cheap crack are you smoking? that has to be some of the stinkiest bullshit i've read here in the last week.
DO the internet a favour and unlearn how to use a web browser.
Corona RT142
Campbelltown
Re: Carburettors vs EFI Wed, 21 September 2005 03:34 Go to previous messageGo to next message
thechuckster wrote on Wed, 21 September 2005 13:30
having owned:
EFI (MA61)
BMW 850 ran two ecus on its 5L V12, mind you it was plagued by issues of it catching fire Smile
[Updated on: Wed, 21 September 2005 03:34]
Re: Carburettors vs EFI Wed, 21 September 2005 03:39 Go to previous messageGo to next message
the BMW ran 2 ECU cause it was easier/cheaper to treat the V12 as 2x 6cyl engines than develop a new ECU.
was nothing to do with staged injection.
Re: Carburettors vs EFI Wed, 21 September 2005 03:40 Go to previous messageGo to next message
thechuckster wrote on Wed, 21 September 2005 11:39
The 1GZFE does the same, but its only so that if one dies, you can drive around on 6cyls for a while.
Re: Carburettors vs EFI Wed, 21 September 2005 03:41 Go to previous messageGo to next message
Can't we just ban this guy?
Re: Carburettors vs EFI Wed, 21 September 2005 03:45 Go to previous messageGo to next message
river wrote on Wed, 21 September 2005 10:56
Rubbish!
seeyuzz
river
Welcome to the 21st century old man Wink Carbs are great for nostalgia, and they're great when they're in "the zone" but they just can't cater for everything like a well-tuned EFI setup can.
illuminatus
eastern suburbs, melbourne
March 2005
Re: Carburettors vs EFI Wed, 21 September 2005 04:00 Go to previous messageGo to next message
gianttomato wrote on Wed, 21 September 2005 13:41
wont b long at this rate.....
i think he is mentally unstable.
[Updated on: Wed, 21 September 2005 04:04]
illuminatus
March 2005
Re: Carburettors vs EFI Wed, 21 September 2005 04:03 Go to previous messageGo to next message
this is what most would call "getting flammed for pissing people off".
BTW Dorio86 (if that is your real name; bubbles), how long did the flight to japan take?
[Updated on: Wed, 21 September 2005 04:07]
Re: Carburettors vs EFI Wed, 21 September 2005 04:39 Go to previous messageGo to next message
Dorio86 wrote on Wed, 21 September 2005 10:47
even a $200 DIY ECU like megasquirt can control staged injection Razz
Re: Carburettors vs EFI Wed, 21 September 2005 04:43 Go to previous messageGo to next message
Corona RT142 wrote on Wed, 21 September 2005 13:34
actually it ran three ECU's, 1 per bank and one to oversee them both with the fly by wire throttle or some such Wink
Re: Carburettors vs EFI Wed, 21 September 2005 04:45 Go to previous messageGo to next message
illuminatus wrote on Wed, 21 September 2005 14:03
i'm sure that mods could just see what ISP he's posting from Wink
ed_ma61
Lost in the K hole
Re: Carburettors vs EFI Wed, 21 September 2005 05:11 Go to previous messageGo to next message
dont make me lock another one...
ffs - can we keep it on track, or EVERYONE is going to get a warning
Dorio86
Bankstown
August 2005
Re: Carburettors vs EFI Wed, 21 September 2005 05:27 Go to previous messageGo to next message
oldcorollas wrote on Wed, 21 September 2005 14:45
That's the proof, right there. If I was using the same ISP which I'm not.
Corona RT142
Campbelltown
Re: Carburettors vs EFI Wed, 21 September 2005 05:32 Go to previous messageGo to next message
Dorio86 wrote on Wed, 21 September 2005 15:27
Yeah but i can be accessing the site from say 3 ISP's uni, work and home etc.
ed_ma61
Lost in the K hole
Re: Carburettors vs EFI Wed, 21 September 2005 05:33 Go to previous message
FUCK IT - THATS IT
OVER
LOCKED
Previous Topic:torque converter 1j and 2j
Next Topic:TA22 diff ratio?
Current Time: Sat Oct 17 21:20:26 UTC 2026
Total time taken to generate the page: 0.0070531368255615 seconds
