Toymods » Tech & Conversions » 1GGTE Single Turbo
MarkIIGT
September 2005
icon5.gif  1GGTE Single Turbo Tue, 20 September 2005 23:40 Go to next message
I have a 3rd Gen 1GGTE and im wanting to upgrade to a single T04 turbo setup.
im wondering what are the limits of the stock 1g in regards to this type of conversion? Will i need to upgrade the injectors, ecu, AFM etc?
I have tried heaps of searches but can't find a good answer on this stuff. I know there's plenty of guys out there who've done this upgrade so If anybody could help me out that would be great
Re: 1GGTE Single Turbo Wed, 21 September 2005 03:15 Go to previous messageGo to next message
You'll get the best benefits by going aftermarket ecu.
Otherwise you'll need to purchase a few piggybacks to be able to safely boost past stock fuel cut.
A set of 7MGTE 440cc injectors, and a Microtech LT10S ecu would be the best route while keeping $$ on the lowdown.
Fattony
Re: 1GGTE Single Turbo Thu, 22 September 2005 00:08 Go to previous messageGo to next message
Not to say that you still wont be able to run the single turbo setup with the stock ecu, you just have to make sure that your afm isnt being pulled open to much due to the higher cfm produced by the bigger turbo, this can be adjusted by tighting the spring on the afm sprocket under the black lid, though yes aftermarket ecu and bigger injectors are a must for you to make good use of this turbo. Yes your motor if in good condition will handle what you should be able to give it as they are tough as nails
EMP-2TG
Carlingford, Sydney
Re: 1GGTE Single Turbo Thu, 22 September 2005 00:38 Go to previous messageGo to next message
im running a setup similar to what CrUZsida talked about
its a easy cheap way to get power out of a 1g
MarkIIGT
September 2005
Re: 1GGTE Single Turbo Thu, 22 September 2005 00:56 Go to previous messageGo to next message
Cheers for the info guys, good stuff!
EMP-2TG... is that dyno sheet of 250kw in your avatar done with the 1g setup your talking about?? what else have you done to get that sort of figure?
Corona RT142
Campbelltown
Re: 1GGTE Single Turbo Thu, 22 September 2005 01:06 Go to previous messageGo to next message
MarkIIGT wrote on Thu, 22 September 2005 10:56
Yes it is.
EMP-2TG
Carlingford, Sydney
Re: 1GGTE Single Turbo Thu, 22 September 2005 01:20 Go to previous messageGo to next message
yeah thats itit made 250.9rwkw on 22-23psi
that was very rich tho, so if i keep it and ever get it tuned and running 100% im hoping for around 280kw
its a stock 1g running a y-pipe adaptor and a t70 turbo
40mm hks copy wastegate
3" all the way
hybrid copy front mount with 3" piping
xf throttle body and custom plenum
7mgte injetors
microtech LTX12s comp
+ heaps of little stuff
Dirty_Sanchez
Re: 1GGTE Single Turbo Thu, 22 September 2005 02:50 Go to previous messageGo to next message
250kw's nice. i'm hoping for some decent power when i get my twin gt28r setup going.
Re: 1GGTE Single Turbo Fri, 23 September 2005 01:42 Go to previous messageGo to next message
Dirty_Sanchez wrote on Thu, 22 September 2005 10:50
With two of those, I'd be hoping for bullshit power levels to match the lag.
MarkIIGT
September 2005
Re: 1GGTE Single Turbo Fri, 23 September 2005 01:52 Go to previous messageGo to next message
I was gunna say, lag factor would be pretty big with two of those things
Grant
Newcastle, NSW, Australia
Re: 1GGTE Single Turbo Fri, 23 September 2005 02:50 Go to previous messageGo to next message
Provided they are sized correctly, lag is not really an issue these days with modern turbo's. Unfortunately a lot of guys go for turbo's that are too big and make a quick street drivable car into a one only good for 1/4 mile squirts.
Fattony
Re: 1GGTE Single Turbo Fri, 23 September 2005 03:23 Go to previous messageGo to next message
Its also wise to keep in mind the capacity of your motor, what power level your chasing and wat style of driving you want out of the car, (i.e you aint gonna have a 8 sec 1/4 mile car to be a quick traffic light dragger) in my opinion there is no point to having a car that can do nothing but spool late spin wheels or just bog down. Power being one thing but drivability is the keep to a quick car and at the expense of a little drivability is the only way you will acheive more power, it all just depends on how far up the scale you think that its nessesary to take.
Grant
Re: 1GGTE Single Turbo Fri, 23 September 2005 03:44 Go to previous messageGo to next message
Well said!
stradlater
Arthurs Creek, Victoria
Re: 1GGTE Single Turbo Fri, 23 September 2005 04:24 Go to previous messageGo to next message
God damn it, Bigger is ALWAYS BETTER!!!!!
*Points at his turbo... *
hehe
I mean lets face it, I don't have any turbo lag at all...
[Updated on: Fri, 23 September 2005 04:24]
EMP-2TG
Carlingford, Sydney
Re: 1GGTE Single Turbo Fri, 23 September 2005 05:48 Go to previous messageGo to next message
points to my turbo, this is what we call atad on the large side, but it was the right price, i could prob make the same outright power and come on boost 2000rpm fast with the perfect turbo combo, tho the 3" intercooler piping and huge throttle body dont help with that either... but god damn its worth the wait Very Happy
mic*
July 2005
Re: 1GGTE Single Turbo Fri, 23 September 2005 07:06 Go to previous messageGo to next message
Is there a difference in any of the internal aspects of a 1G-GTE as compared to a GZE?
I have the same car as MarkIIGT but the S/C version.
The life of this S/C has little future... The clutch shits me, there is no power progression, and its nearly impossible to IC so it runs so freakin hot...
I cant imagine whats gonna happen if i do the pulley change iv been contemplating without some form of cooling. ATW is expensive, and custom, and still bloody hard to fit without dragging something on the ground.
dayzii
Perth W.A
Re: 1GGTE Single Turbo Fri, 23 September 2005 07:23 Go to previous message
i believe the GZE has lower comp?
Previous Topic:Electronic Boost Controllers...which is better??
Next Topic:TA22 door hinges /same as RA40/28/23???
Current Time: Sun Oct 25 22:46:07 UTC 2026
Total time taken to generate the page: 0.063033103942871 seconds
