Toymods » Tech & Conversions » Multiple throttle bodies + forced induction
-=DV=-
Newcastle, NSW
Multiple throttle bodies + forced induction Wed, 21 September 2005 00:55 Go to next message
hey i was just reading an efi vs carby thread and it was stated that throttle body per cylinder setups gave greatly increased engien response and flow. given this is for n/a engines, i can only assume the better flow and response would be even more noticable on FI engines? what do u guys reckon..and why?...im sort of trying to get ideas on ultimately where to take my gtfour...EVENTUALLY i want to do something really different with it.
Skip
Re: Multiple throttle bodies + forced induction Wed, 21 September 2005 01:37 Go to previous messageGo to next message
Look at the factory setup on the RB26DETT, SR20DET GTiR version and the 2L in the Cosworth Sierra.
Henn
Rosanna, Melb
Re: Multiple throttle bodies + forced induction Wed, 21 September 2005 01:45 Go to previous messageGo to next message
I have seen multi throttle bodies run on FI engines (namely turbo 20Vs, and GTRs) and clearly it works. However I don't think they are quite as important as on an NA car.
This is because ITBs become useful when chasing that extra little bit of flow (and therefore power) on a hard built NA engine. On an FI engine they should do the same thing, but the same result could be achieved but turning the boost up ever so slightly. Less effort for the same result.
Also I've read that when chasing BIG horsepower, the multithrottles on GTRs are ditched for a big single. No solid backup for that last one though.
Hen
Re: Multiple throttle bodies + forced induction Wed, 21 September 2005 02:54 Go to previous messageGo to next message
GTR's are converted to a big single throttle purely for cost reasons. A custom plenum is cheaper than 6x larger throttles.
Re: Multiple throttle bodies + forced induction Wed, 21 September 2005 03:01 Go to previous messageGo to next message
Henn wrote on Wed, 21 September 2005 11:45
Usually because one big throttle body is cheaper than 6 slightly bigger throttle bodies. Also drag engines/dyno queens aren't usually chasing instant throttle response or a flat midrange.....
bluehachi
September 2005
Re: Multiple throttle bodies + forced induction Wed, 21 September 2005 04:27 Go to previous messageGo to next message
Norbie wrote on Wed, 21 September 2005 12:24
i think you will find its also for tuning reasons. Its a lot easier to tune a single throttle setup then a multiple set up. However multiple throttle set ups when done right, seem to be the better result.
Re: Multiple throttle bodies + forced induction Wed, 21 September 2005 04:43 Go to previous messageGo to next message
I was considering doing this on my 3S-GTE project.
Was going to use 20v blacktop throttles with an adapter plate and then a plenum over them.
Ended up getting a bit costly so stuck with the standard single throttle setup.
But good luck with it, very interested to see how you get on.
I might investigate it again down the track.
Joel
-=DV=-
Newcastle, NSW
Re: Multiple throttle bodies + forced induction Wed, 21 September 2005 10:52 Go to previous messageGo to next message
thanks guys, im just tossing up ideas of where id like to take the gtfour in the very very distant future...ultimately i would like high boost + alot of throttle response...i was thinking about twin charging it (turbo + sc) for a while and its still on my mind but yeah im not deciding on for anything probably atleast a year or 2 yet as it has to be my daily driver for quite a while yet Sad...so im more or less trying to build my knowledge base so i can decide where to take it when the time comes Smile
thanks for all the replys
[Updated on: Wed, 21 September 2005 10:54]
t18_psi
perth wa
June 2005
Re: Multiple throttle bodies + forced induction Thu, 22 September 2005 01:49 Go to previous messageGo to next message
on the topic of gtr's..
ive read some workshops ditch the multi throttle setup for a BIG single throttle because at full throttle the single throttle will cause less of a restriction than the six smaller ones.
i havnt seen any dyno proof of gains tho...
Re: Multiple throttle bodies + forced induction Thu, 22 September 2005 02:17 Go to previous messageGo to next message
t18_psi wrote on Thu, 22 September 2005 09:49
Unless it's a massive throttle body, I doubt it. From what I've read it's to do with cost and ease of tuning.
M.W.P.
Rocky Mountains, Canada
Re: Multiple throttle bodies + forced induction Thu, 22 September 2005 07:06 Go to previous messageGo to next message
t18_psi wrote on Thu, 22 September 2005 11:19
This is fine if your at WOT all the time.
It would be hell for daily road driving.
ed_ma61
Lost in the K hole
Re: Multiple throttle bodies + forced induction Thu, 22 September 2005 07:15 Go to previous messageGo to next message
mmmmm multiple throttlw bodies Shocked Shocked Shocked
http://www4.tpg.com.au/users/loats/images/Image0022a.jpg
as everyone has suggested, better response, better mid range, less top end. less useful on FI than NA, but still good (see rb26dett etc etc)
ed
Manny
Re: Multiple throttle bodies + forced induction Thu, 22 September 2005 08:26 Go to previous messageGo to next message
Nice plenum Ed Very Happy
-=DV=-
Newcastle, NSW
Re: Multiple throttle bodies + forced induction Thu, 22 September 2005 11:11 Go to previous messageGo to next message
ed_ma61 wrote on Thu, 22 September 2005 17:15
ed
ed if i was to use 4 stock 3sgte throttle bodies on a custom manifold of some discription, would there nessecarily be a negative effect on top end?
Re: Multiple throttle bodies + forced induction Thu, 22 September 2005 11:22 Go to previous messageGo to next message
unless it's a W16 engine I can't see why you'd want to. ITBs are a lot smaller than single throttles. (and I'm 90% sure the 3s in all forms is single throttle/plenum)
tricky
July 2005
Re: Multiple throttle bodies + forced induction Thu, 22 September 2005 11:57 Go to previous messageGo to next message
BEAMS has quads AFAIK Smile no 3SGTE had quads though. 4 x 3SGTE throttles on a cusso manifold would probably suck. I'd hazard a guess that you'd have a lot of difficulty getting a plenum to fit around such big ass throttles, not to mention port spacing could be a limiting factor!
Scorpion
Menai area of Sydney
Re: Multiple throttle bodies + forced induction Thu, 22 September 2005 22:17 Go to previous messageGo to next message
Individual throttle bodies per cylinder benefit n/a as you can tune the length and diameter to set up standing pressure waves that time the maximum air intake with the valve opening time.
This can also be tuned to affect the rev range that it is most effective over. Forced induction (depending on amount of boost) can override these standing waves and with enough boost cause greater volume of air intake anyway.
[Updated on: Thu, 22 September 2005 22:17]
Re: Multiple throttle bodies + forced induction Thu, 22 September 2005 23:03 Go to previous messageGo to next message
I didn't think the BEAMS 3SGE had quad throttles. 3SGTE TB's are tiny as well, but still larger than I'd want to use as ITB's Smile
3sfe
Re: Multiple throttle bodies + forced induction Thu, 22 September 2005 23:16 Go to previous messageGo to next message
I remember when i had a gen 2 3sge, in the manifold there was some sort of tvis setup but it was on all 4 runners but they where about 6-8" from the head could something like that be setup to be used as TB's? I guess the main concern would be if it could handle high psi. Just a thought
ed_ma61
Lost in the K hole
Re: Multiple throttle bodies + forced induction Thu, 22 September 2005 23:54 Go to previous messageGo to next message
Manny wrote on Thu, 22 September 2005 18:26
piece of crap No No No
Laughing
Henn
Rosanna, Melb
Re: Multiple throttle bodies + forced induction Fri, 23 September 2005 01:24 Go to previous messageGo to next message
Scorpion wrote on Fri, 23 September 2005 08:17
Individual throttle bodies per cylinder benefit n/a as you can tune the length and diameter to set up standing pressure waves.
That's true as far as my basic understanding goes.
I disagree slightly here. Having higher than atmospheric pressure in the plenum shouldn't affect the whole standing wave issue (other than maybe a change in their speed of propogation), you can still tune your runners and bellmouths on an FI engine. The boost doesn't "override" the intake tuning.
It's just that it is often not worth the effort doing so much intake tuning on an FI engine as you can just up the boost a little for the same result.
Hen
moo4AGZETA22
Tasmania
Re: Multiple throttle bodies + forced induction Fri, 23 September 2005 01:51 Go to previous messageGo to next message
One of the biggest advantages of ITB in a N/A set-up is the ability to fire the injector down the length of the T/B trumpet. This leads to a superior atomisation of the fuel.
A good place to see this is with the old 2 litre Super Tourers. The were putting out ~300hp from 2 litres.
There are photos of the Ferrar 550 that was privately run at Le Mans that shows injectors firing down the trumpets to all 12 cylinders.
Another point, one large T/B doesn't have anywhere near the flow ability of ITBs.
Justin
ed_ma61
Lost in the K hole
Re: Multiple throttle bodies + forced induction Fri, 23 September 2005 03:29 Go to previous messageGo to next message
thats crap... sure, upstream injectors are 'a' benefit, but certainly not the 'main benefit'...
as for mass flow capability... hmmmm... so tell me why a 'driver's vehicle' would have ITBs, but a crazy WOT drag car runs a single large throttle?
and yes, harmonic tuning is still just as relevant on an FI engine as it is in NA...
Re: Multiple throttle bodies + forced induction Fri, 23 September 2005 03:46 Go to previous messageGo to next message
Anyways....
it can be done. However, there are cheaper ways of ensuring good throttle response from a FI car than by setting up ITBs. Plenum design, runner length, well matched roller bearing turbo....you'd be doing all this anyway so why not be smart about it rather than adding an extra degree of difficulty?
M.W.P.
Re: Multiple throttle bodies + forced induction Fri, 23 September 2005 04:20 Go to previous messageGo to next message
ed_ma61 wrote on Fri, 23 September 2005 12:59
Agreed, but if it helps, why not set it up?
It does have an effect on drivability though.
Factory sequential injectors are setup to spray fuel onto the back of the closed inlet valves which then causes the fuel to evaporate which gives better fuel economy and low-rpm torque.
High RPM power is helped by having the injectors mounted just above the inlet trumpets.
Toyota F1 engine inlets:
http://www.overclockers.com.au/~mwp/temp/F1Engine9.jpg
[Updated on: Fri, 23 September 2005 04:20]
ed_ma61
Lost in the K hole
Re: Multiple throttle bodies + forced induction Fri, 23 September 2005 04:54 Go to previous messageGo to next message
more pics of ^^^^^^ f1 engine??
Re: Multiple throttle bodies + forced induction Fri, 23 September 2005 05:14 Go to previous messageGo to next message
M.W.P. wrote on Fri, 23 September 2005 14:20
not necessarily true Wink, it depends greatly on the particular engine involved as to what phasing is the best for power or emissions, and those two points to not necessarily coincide.
many factory injectors actually spray against the side of the ports, which helps atomisation not from the jet of fuel itself, but from the rebound/spray off the port wall
for high rpm motors, because of the high intake velocity, more time may be required for decent mixing, and time = distance. can't afford to have sharge stratification in a high $ motor (unless it is designed for it Wink).
for a motor which is NOT going to be run at WOT all the time, there is little benefit in fitting high injectors, and the couple of % difference will not be noticed/useful.
perhaps Razz
M.W.P.
Re: Multiple throttle bodies + forced induction Fri, 23 September 2005 05:46 Go to previous messageGo to next message
ed_ma61 wrote on Fri, 23 September 2005 14:24
Yeh, lots...
I cant find them on the net again, so ill have to upload them.
Will take a little while.
M.W.P.
Re: Multiple throttle bodies + forced induction Fri, 23 September 2005 06:01 Go to previous messageGo to next message
Here:
http://www.overclockers.com.au/~mwp/gallery/?l=Oth er/Toyota%20F1%20Headquerters%202005
Mr Revhead
nelson, new zealand
Re: Multiple throttle bodies + forced induction Fri, 23 September 2005 06:44 Go to previous messageGo to next message
guess what the TRD intakes for the 3sge are made from...
bathurst-91
Re: Multiple throttle bodies + forced induction Sat, 24 September 2005 23:54 Go to previous message
Hen
Couldnt have stated it better myself. Once you cross a certain threshold on bigturbo engines you just basically want to get as much air in there as possible Smile
Previous Topic:Suggestions on mags for KE55
Next Topic:clutch problems, help
Current Time: Sat Oct 31 03:56:35 UTC 2026
Total time taken to generate the page: 0.023066997528076 seconds
