Toymods » Tech & Conversions » Ae82 Front wheel hub torque value
Viper_III
Hawthorn, Vic
March 2005
icon3.gif  Ae82 Front wheel hub torque value Thu, 22 September 2005 00:22 Go to next message
hey guys,
just a quickie.
On the front wheel hubs on an ae82, how tight should the centre nut be?
tight as a bitch? or tighten it up like hell, then back off a 1/2, 1.4 turn??? or is there a specific torque it needs to be???
ive previusly done it right up tight, then backed of 1/4 turn or so.
but talking to a mechanic, they do it right up with a rattle gun.
also mumbled something about the ae82 hubs needed to be bolted tight to the axle.
anyone have any idea?
cheers!
rxjohn
Melb VIC
Re: Ae82 Front wheel hub torque value Thu, 22 September 2005 03:44 Go to previous messageGo to next message
when i undone mine had to use long bar thru wheel(car on ground) to undo nut, used same method to do up, tight as you possibly can, then fit split pin .
[Updated on: Thu, 22 September 2005 03:45]
Hunty
Re: Ae82 Front wheel hub torque value Thu, 22 September 2005 04:48 Go to previous messageGo to next message
i used a 1m steel bar and good socket set to undo mine and still bent the bloody rachet handle. When i did it backup i almost lifted the bloody thing off the ground, bent the handle on the rachet back tho Razz in short if you dont want your wheel to come off do it up toight loike a toiger
Viper_III
Hawthorn, Vic
March 2005
Re: Ae82 Front wheel hub torque value Thu, 22 September 2005 06:49 Go to previous messageGo to next message
fair enough
tight as buggery it is
cheers!
toof
Re: Ae82 Front wheel hub torque value Thu, 22 September 2005 09:05 Go to previous message
one of the ones in the mr2 taking it off i had the breaker bar then a 1.5m steel pole over that and it only let go after a fair bit of provocation.
bent the crap outa the iron pole Sad
Previous Topic:Timing Chain Tensioner oil leak?
Next Topic:3sge with altezza box
Current Time: Fri Oct 30 03:49:54 UTC 2026
Total time taken to generate the page: 0.11282110214233 seconds
