Toymods » Tech & Conversions » corona strut question
RA28
corona strut question Fri, 03 January 2003 06:25 Go to next message
The corona (xt130) struts for the celica brake upgrade, will RA28 suspension parts fit on this? in particular a set of Koni reds?
Also, is this strut the same as the RT132 strut? I noticed that has a twin piston caliper but only a 10" disk I think. Is the axel stub the same size?
Tim.
[Updated on: Fri, 03 January 2003 07:52]
TOY77
Re: corona strut question Sun, 05 January 2003 07:30 Go to previous messageGo to next message
G'day Tim,
The 28 suspension stuff will fit as i swapped all my after market stuff over.... including shocks and springs.
Can't help u with the other question though, sorry...
Stew
EVOSTi
cambo
      no
Re: corona strut question Sun, 05 January 2003 10:45 Go to previous messageGo to next message
im doing this upgrade on my sprinter and the wrecker allowed me to borrow a strut and told me that they are the same so i took it and the RT132 strut is different, the distance between the caliper mounting bolt holes IS NOT 90mm so its useless.
[Updated on: Sun, 05 January 2003 10:47]
RA28
Re: corona strut question Sun, 05 January 2003 11:34 Go to previous messageGo to next message
thanks guys for the help.
i was asking about the rt132 struts cause i have an rt132 in the backyard and thought maybe it might be useful for something, but now it turns out it isnt.
Tim.
Bugman
Re: corona strut question Sun, 05 January 2003 11:52 Go to previous messageGo to next message
sure about the rt132 struts? I'll have to check my ones I thought I had rt132 and they were 90mm may have been rt133 if they exist..
demuire
Ipswich
Re: corona strut question Sun, 05 January 2003 12:09 Go to previous messageGo to next message
Hmm, I've got XT130 struts on my Rolla and RT132 struts in my garage, but no spare XT130 callipers to see if they fit on the RT132 struts... How do I measure this?
TE72_Turbo
Re: corona strut question Sun, 05 January 2003 12:14 Go to previous messageGo to next message
I'm really interested in this too as I "thought" mine were RT132.
demuire: you just need to measure the distance beween the centres of the two large bolts that hold the caliper to the strut leg.
Please let us know!
Phil
demuire
Ipswich
Re: corona strut question Sun, 05 January 2003 12:20 Go to previous messageGo to next message
I just did a rough measurement with a measuring tape, it looks like 90mm to me. If it's out, it's not out by much.
I'm 100% certain my struts aren't from an XT130, and I am about 80% certain they are from an RT132. If it helps at all, the "donor" car was a sedan, and it had a 21RC in it.
RA28
Re: corona strut question Mon, 06 January 2003 03:31 Go to previous messageGo to next message
Ok here is a pic of the 132 strut
http://www.geocities.com/kpamente/
could someone verify it? the bolt holes are 90mm and the axel looks about 35mm.
Tim.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: corona strut question Mon, 06 January 2003 03:51 Go to previous messageGo to next message
Now I don't suppose any of you guys have a spare LHS corona strut lying around doing nothing do you? 130 or 132, pending the outcome of this thread..... Smile
demuire
Ipswich
Re: corona strut question Mon, 06 January 2003 04:04 Go to previous messageGo to next message
I might have a spare LHS, but I'm in Brisbane.
EVOSTi
cambo
      no
Re: corona strut question Mon, 06 January 2003 06:03 Go to previous messageGo to next message
well... i may be miss informed becuase i asked the wrecker for an XT130 strut and received an RT132 strut and was told they were the same, but when i got it home the caliper mounting holes werent the right spacing, so he must have given me a different strut becuase i never saw it on the car. if this is the case dissregard my last comment. im happy either way tho cause i definately have XT130 struts i took them from the car myself. Very Happy
GEEZE23
Western Sydney
Re: corona strut question Mon, 06 January 2003 09:23 Go to previous message
Not all Coronas have the same brakes, some are Aus built, some are Jap built. The types of brakes are single piston sliding type (with large mounting hole spacing); and twin piston fixed type (with 90mm bolt hole spacing). RT132s had both types, you have to get the right ones; Same as engines, some coronas has 18Rs, 20Rs, 21Rs, 1Xs, etc. The brakes changed according to engine/transmission/body shape/plant build config. Good luck
All the shocks are interchangeable with 23/8 and 40/60 celicas i believe.
.oO Dave Oo.
[Updated on: Mon, 06 January 2003 09:26]
Previous Topic:differential options for AE86
Next Topic:Injector Wiring
Current Time: Tue Oct 20 22:35:43 UTC 2026
Total time taken to generate the page: 0.039989948272705 seconds
