Toymods » Tech & Conversions » KE70 diffs???
chrisevans1985
North Ringwood
KE70 diffs??? Thu, 22 September 2005 11:38 Go to next message
is the ke70 the one with the t series diff?
is that the diff housing u can buy all the trd and kaaz centres for?
newbien
adelaide
August 2005
Re: KE70 diffs??? Thu, 22 September 2005 12:15 Go to previous messageGo to next message
no,
the t series rear end comes on the T-18 ( TE72 )
Re: KE70 diffs??? Thu, 22 September 2005 14:42 Go to previous messageGo to next message
chrisevans1985 wrote on Thu, 22 September 2005 21:38
KE70 has a bog warmer in it
love ke70
September 2005
Re: KE70 diffs??? Thu, 22 September 2005 14:58 Go to previous messageGo to next message
u say bog warmer...wats wrong with a borg warner diff??
beige_bandit
September 2005
Re: KE70 diffs??? Thu, 22 September 2005 22:20 Go to previous messageGo to next message
not all ke70 diff are barg warner!
my panel van has an japanese diff in it
3 different types of rear end it can have!
chrisss
melb
Re: KE70 diffs??? Fri, 23 September 2005 05:11 Go to previous messageGo to next message
KE70 had if its aussie made the bo(r)g warner diff...
if its a import like the T18 and the panelvan it had a jap diff, T and S respectivly..
I had a PV with 4ag and I swapped the Sjap diff for a borg warner and it held up fine... u can get the borg warner in 3.9, 4.1 and 4.3 ratio where as the PV Sjap diff was only 3.9..also good luck finding a PV diff but the wagon diffs r quite common....though I could never find a wagon with the 4.3 diff..
Re: KE70 diffs??? Fri, 23 September 2005 05:18 Go to previous messageGo to next message
the panel vans are significantly different to the sedans and wagons, and are more like AE7X PV than KE. ie brakes are same as sprinter (238?mm vs 218mm), diff is same as sprinter etc.
AE71? Bog or jap?
beige_bandit
September 2005
Re: KE70 diffs??? Fri, 23 September 2005 05:32 Go to previous messageGo to next message
australian delivered and sold ke70 panelvan
with jap rear end :s312
panelvan has leafsprings, sprinter has coil+shock
chrisss
melb
Re: KE70 diffs??? Fri, 23 September 2005 06:25 Go to previous messageGo to next message
yeah the panelvans were australian delivered and sold but they were imported by toyota ie not manufactured here...
AE71(sedan and wagon) was basically australian manufactured....it had a lot of aussie stuff in it...It had the borg warner diff in it...
AE71 (PV) import....
beige_bandit
September 2005
Re: KE70 diffs??? Fri, 23 September 2005 08:04 Go to previous messageGo to next message
is the KE70 pv an import aswell then?
chrisss
melb
Re: KE70 diffs??? Fri, 23 September 2005 10:14 Go to previous messageGo to next message
yep
Purple_Beasty
New Zealand
Re: KE70 diffs??? Fri, 23 September 2005 20:32 Go to previous messageGo to next message
If you look internationally, most of the KE70's ran the U code diff. TRD LSD was available for those, but discontinued now I believe.
Callum
Re: KE70 diffs??? Sat, 24 September 2005 08:05 Go to previous message
love ke70 wrote on Fri, 23 September 2005 00:58
1. They're noisy buggers
2. They break real easy...
3. They're a bit more of a mongrel to fix up than the other diffs when you do break them
4. They can get some pretty amazing backlash in them Razz
5. They're a bogwarmer product, what else should be said?
Previous Topic:7MGTE weird cut out under boost/load?? ---SOLVED!!!!
Next Topic:Ultimate K motor?
Current Time: Sat Oct 17 13:34:53 UTC 2026
Total time taken to generate the page: 0.0061309337615967 seconds
