Toymods » Tech & Conversions » 2T Dieing
badboybubby
On Probation
2T Dieing Thu, 22 September 2005 12:27 Go to next message
Hi ppl my TA22 has just started stuttering/dieing under load (but will free rev fine) at about 4500 rpm Ive done the points and a tune but its still doing it? would it be the leads Id just done the soak with WD40 then mist water into the carb decarbonise thing too now I think of it Sad
Any Ideas
hemi twofifteen turbo
Re: 2T Dieing Thu, 22 September 2005 13:32 Go to previous messageGo to next message
could be the plugs or leads. check weather or not your spark plug holes are full of oil. The tube seals leak oil from the rocker in and 'wet' the leads causing missfire under load. That or change plugs. Definaly sounds like igntion system I think. Would it keep revving all the way up if you gave it time or is it just hitting a wall? (if hitting wall suspect blocked fuel line etc)
badboybubby
On Probation
Re: 2T Dieing Fri, 23 September 2005 03:00 Go to previous messageGo to next message
Yep thats definitely an option
badboybubby
On Probation
Re: 2T Dieing Mon, 26 September 2005 01:53 Go to previous message
Sorted it it was the little metal cap in the fuel filter had fallen off and would fall back and block the hole under acceleration Laughing
Gotta love the easy ones
Previous Topic:RA60 Struts/Shocks - What other cars fit in.... ???
Next Topic:7M-GTE hunting at idle.
Current Time: Fri Nov 20 14:56:40 UTC 2026
Total time taken to generate the page: 0.010709047317505 seconds
