Toymods » Tech & Conversions » Fuseing headunit if direct to battery
michaelhaynes110
Townsville, QLD, Australia
June 2005
Fuseing headunit if direct to battery Fri, 23 September 2005 04:01 Go to next message
I dont have a constant 12v to hook my headunit up to. I ran a wire straight to the battery to take care of this. The headunit has a fuse so should i be bothered putting one between the wire and battery? Should I make it more or less that the headunits internal fuse?
Dale_ta22
Forster NSW
Re: Fuseing headunit if direct to battery Fri, 23 September 2005 04:10 Go to previous messageGo to next message
Yes you should use a fuse on that.
Use a 10-15amp fuse for this, best to locate it close to the battery if possible.
Stefan
Hobart, Tas
Re: Fuseing headunit if direct to battery Fri, 23 September 2005 04:52 Go to previous messageGo to next message
I put a dist block near the battery with fuses, then ran wire from this to headunit.
Re: Fuseing headunit if direct to battery Fri, 23 September 2005 05:19 Go to previous messageGo to next message
michaelhaynes110 wrote on Fri, 23 September 2005 14:01
you don't have an interior light or a clock?
michaelhaynes110
June 2005
Re: Fuseing headunit if direct to battery Fri, 23 September 2005 10:32 Go to previous message
Ok, I don't have a 12v that is easy to get to Razz.
Went and got an inline 15 amp fuse today and I will just connect it in between the battery and the wire.
Previous Topic:MA70 Auto to Manual Conversion
Next Topic:ca18det into my Corolla
Current Time: Sat Nov 21 15:54:56 UTC 2026
Total time taken to generate the page: 0.0084171295166016 seconds
