Toymods » Tech & Conversions » RA40 diffs
tricky
July 2005
RA40 diffs Fri, 23 September 2005 10:41 Go to next message
Can anyone tell me the difference in width between RA40 and RA23 diffs?
Cheers.
Re: RA40 diffs Fri, 23 September 2005 10:43 Go to previous messageGo to next message
width - RA40 is wider
tricky
July 2005
Re: RA40 diffs Fri, 23 September 2005 10:54 Go to previous messageGo to next message
yeah, I know, but does anyone know by how much?
brett_celicacoupe
townsville NQLD
Re: RA40 diffs Fri, 23 September 2005 11:28 Go to previous messageGo to next message
im pretty sure , quoting from another thread that they are;
RA40 - 1410
xA2x - 1370
tricky
July 2005
Re: RA40 diffs Sat, 24 September 2005 02:57 Go to previous messageGo to next message
Thanks Brett! Very Happy
RA40Celica
Hobart
  chris_rg@jabber.org
Re: RA40 diffs Sun, 25 September 2005 00:59 Go to previous messageGo to next message
hmm... are the mounting points the same?
can they be swapped?
tricky
July 2005
Re: RA40 diffs Sun, 25 September 2005 02:05 Go to previous messageGo to next message
yeah, the mounting points are the same. I beleive that TA22/*A23/RA28/RA40 diffs all have the same mountings, but they get progressively wider in order of chronology.
Allan
Re: RA40 diffs Sun, 25 September 2005 04:03 Go to previous messageGo to next message
put a G series in thats the plan for my MA45 Smile exactly the right width for A4 series Smile
tricky
July 2005
Re: RA40 diffs Sun, 25 September 2005 04:29 Go to previous messageGo to next message
No G series for me! F all the way... 'twill be IRS of course. The reason I asked about RA40 width is I found a post where a dude shoved an RT142 IRS in an RA40, and I beleive there are vast similarities between the RA40 and RA23 as far as floorapn and diff are concerned. Now I don't wanna put an RT142 diff in my car, 'cos they are a crappy design, but I'm just doing some reccy before I get a shell to do prototyping on. My ultimate goal is to get *A70 or JZA80 double wishbone stuff under there, but there is significant weight involved, and the track widths are significantly wider...
Maurice c
Re: RA40 diffs Sun, 25 September 2005 12:15 Go to previous messageGo to next message
Good luck mate, its a tall order, I reckon that you'll need some specialist equipment to keep it straight.
Re: RA40 diffs Mon, 26 September 2005 01:23 Go to previous messageGo to next message
An S13 rear end might be a closer fit if you want decent IRS. Heaps of aftermarket gear (diffs etc) available for them too.
tricky
July 2005
IRS to RA23 Mon, 26 September 2005 02:56 Go to previous message
yep, S13 is definitely on my wishlist. They are of a much lighter design than the *A70 supras, and they should be relatively available, due to the excess of smashed up drift cars Rolling Eyes . As far as specialist equipment to keep the bugger straight, a modular design of high adjustability is required and planned, but careful placement of the brackets should ensure that it is pretty straight prior to adjustment.
Essentially, I'll have a shell to work on, so it is easy to prototype everything without having to worry about the road car being put out of action. All up, it shouldn't be an overly expensive exercise. As long as the planning phase is complete before anything is cut, altered or purchased, the main investment will be time.
Just out of curiosity, what are the widths of S13, R33 and MA70 rear ends?
Previous Topic:ra65 struts and brakes in a ke30
Next Topic:D and T series diffs
Current Time: Fri Nov 20 12:47:21 UTC 2026
Total time taken to generate the page: 0.0097119808197021 seconds
