Toymods » Tech & Conversions » RA60 Struts/Shocks - What other cars fit in.... ???
ed_ma61
Lost in the K hole
RA60 Struts/Shocks - What other cars fit in.... ??? Fri, 23 September 2005 12:37 Go to next message
Ok, im just looking at what different car model shocks can be sucessfully installed in RA60 struts...
now seeing as the RA60 struts can be put into AE86s, im guessing the whole SW20 REAR thing can be applied to the RA60 struts aswell? + spacers?
Bbaacchhyy has put Rav4 untits in his (cant remember front or rear) + spacers?
Ive also heard something about commonwhore shocks fitting??
Anyone know any altrnatives? or even details of the RA60 shock dimensions, and where i can find a reliable data sheet so i can go looking myself?
ed
[Updated on: Fri, 23 September 2005 13:09]
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: RA60 Struts - Alternative Shocks.... ??? Fri, 23 September 2005 12:44 Go to previous messageGo to next message
I have Koni Yellows up front and Koni Reds out back.
Also had some K-Mac jobbies up front. And Monroes in the back.
The DunnyDoor shocks were for the rear, can't remember the exact details though.
ed_ma61
Lost in the K hole
Re: RA60 Struts - Alternative Shocks.... ??? Fri, 23 September 2005 13:00 Go to previous messageGo to next message
ok, i should clarify - i didnt quite mean brand of shock, rather, what alternative car models share similar dimensions: eg will a VB commodore front shock fit into the RA60 strut tube? etc etc
Nark
Cabramatta, NSW
Re: RA60 Struts - Alternative Shocks.... ??? Fri, 23 September 2005 13:06 Go to previous messageGo to next message
Ah. OK.
No idea. Very Happy
What are you planning to do with this info?
ed_ma61
Lost in the K hole
Re: RA60 Struts/Shocks - What other cars fit in.... ??? Fri, 23 September 2005 13:14 Go to previous messageGo to next message
im hoping that the australian market, full of cheap accesories for commonwhores and falcons etc, might be able to provide a broader range of locally available options for shocks for my RA60 struts...
if you ask for high performance RA60 shocks, you might imagine the 'fuck all' response i often get Nod
Stefan
Hobart, Tas
Re: RA60 Struts/Shocks - What other cars fit in.... ??? Fri, 23 September 2005 15:54 Go to previous messageGo to next message
Yes, Sw20 mr2 strut inserts fit - I have rear ones ehre I plan to use in mine with a ~40mm (rough estimate as I don't have stock ones out to compare to) spacer. Front ones are even shorter still, IIRC (it was a long time ago I worked this out) ~60mm shorter. Lots of nice adjustable stuff available for these Smile - I'm got some GAB 8-ways.
Go to monroe.com & have some fun with the online parts ctaalogs and .pdfs of shock dimensions.
Re: RA60 Struts/Shocks - What other cars fit in.... ??? Sat, 24 September 2005 05:40 Go to previous messageGo to next message
I'm using ST18x strut inserts (with spacer) in my front struts... unfortunately they're MX83 struts, and I don't know if the strut tube dimensions are similar to the xA6x.
wilbo666
Re: RA60 Struts/Shocks - What other cars fit in.... ??? Sat, 24 September 2005 14:08 Go to previous messageGo to next message
Hey Ed, this maybe of some use Smile
http://forums.toymods.org.au/index.php?t=msg&t h=26050&rid=36&S=b954f3e362a9b0734796bd6ec a8a1ec7
Steve-AE86 wrote on Mon, 29 December 2003 10:32
to start off, Type refers to this diagram:
http://www.users.bigpond.com/steveg101/shock%20typ es.jpg
Body is the length of the body,
Comp is the compressed length,
Extn is the extended length.
pretty easy, huh..
___________________
MA61
Type T6
Body 397
Comp 408
Extn 617
___________________
SA63/RA60
Type T6
Body 405
Comp 405
Extn 609
___________________
MX62 (9/80-8/82)
Type T5
Body 387
Comp 399
Extn 591
___________________
MX62 (9/80-7/84)
same as MA61
___________________
ST185
Type T6
Body 328
Comp 355
Extn 483
___________________
VB-VP Commodore poo
type T6
Body 405
Comp 405
Extn 599
ok. believe it or not, ALL commodore, from 78-93 will fit SA63 struts, are exactly the right body length, and compressed length, but have 10mm less stroke
bbaacchhyy
Re: RA60 Struts/Shocks - What other cars fit in.... ??? Sun, 25 September 2005 06:12 Go to previous messageGo to next message
Hi Ed,
Yep, RAV 4's fit with only 1 or 2 thick washers.
I have a Monroe Catalogue on CD if you want a copy, and you can search on certain dimensions.
Let me know if you want one and I'll burn a copy.
Certain crumpledore ones fit friont and rear, but as they are getting old now (the ones that fit), they aren't any cheaper in the Koni range, hence why I went for what I got
Michael B
PS Call me on 042 111 9249 if you want a copy
ed_ma61
Lost in the K hole
Re: RA60 Struts/Shocks - What other cars fit in.... ??? Sun, 25 September 2005 09:58 Go to previous messageGo to next message
michael - can you confirm with that catalogue whether VS commodore front shocks will fit in RA60 struts??
Ed
ed_ma61
Lost in the K hole
Re: RA60 Struts/Shocks - What other cars fit in.... ??? Sun, 25 September 2005 11:07 Go to previous messageGo to next message
by the way - among the other dimensions, im specifically concerned about the width/dia of the inserts, and whether theyll fit in the ra60 struts??
ed
bbaacchhyy
Re: RA60 Struts/Shocks - What other cars fit in.... ??? Sun, 25 September 2005 22:45 Go to previous messageGo to next message
Hi Ed,
I think the VR/VS are listed as Superstrut type, whereas the others VB, VC, VH, VK, VL, VN and VP have the same body style (T6), Same body length (405mm), and same extended length of 599mm.
Michael B
ed_ma61
Lost in the K hole
Re: RA60 Struts/Shocks - What other cars fit in.... ??? Mon, 26 September 2005 02:03 Go to previous message
but no info on diameter of the insert?
i looked at the monroe website - not much info there No No No
Previous Topic:D and T series diffs
Next Topic:2T Dieing
Current Time: Fri Nov 20 14:32:32 UTC 2026
Total time taken to generate the page: 0.0073318481445312 seconds
