Toymods » Tech & Conversions » AE92 Oil Pressure a bit high
chillo_burger
AE92 Oil Pressure a bit high Fri, 23 September 2005 15:02 Go to next message
I just bought a 1990 Corolla SX, and at first the oil pressure was sitting on the next line up from the middle. after changing the Oil to 10w-40 the pressure gauge now sits a bit higher...between the line i mentioned before and next one up. At idle the pressure sits at half...but still. Any help and sugestions would be apreciated
chillo_burger
Re: AE92 Oil Pressure a bit high Sun, 25 September 2005 11:51 Go to previous messageGo to next message
Oil Pressure that is too high isnt good for the engine is it?
Scorpion
Menai area of Sydney
Re: AE92 Oil Pressure a bit high Sun, 25 September 2005 13:50 Go to previous messageGo to next message
There is an oil pressure relief valve near the oil pump that should limit the oil pressure anyway. As long as the oil pressure peaks where it is you should be OK. You'll probably find that as the oil ages and/or heats up, the max pressure will drop slightly.
chillo_burger
Re: AE92 Oil Pressure a bit high Sun, 25 September 2005 14:36 Go to previous messageGo to next message
like i drive it around and it just seems high...i'll take a pic of it and show u guys. My friend has a GTi model and his oil pressure is no where near as high as mine. Also we're both using the same oil...i also saw from diagram that there is a relief valve where the oil filter goes. Can this help?
Scorpion
Re: AE92 Oil Pressure a bit high Mon, 26 September 2005 00:45 Go to previous messageGo to next message
The relief valve where the oil filter is is just to allow oil through the oil cooler as well as the filter.
If you have the same engine and are using the same oil it is highly likely that the one with the higher oil pressure is less worn than the one with the lower pressure. When clearances in the bearings are smaller, the oil is harder to push through so the pressure is higher. Doesn't mean the other one is worn out though, just different clearances. If your oil pressure remains above the horizontal line, even when idling, then all should be OK.
chillo_burger
Re: AE92 Oil Pressure a bit high Tue, 27 September 2005 07:12 Go to previous message
Thanks 4 that man...its logical what u said...but im gonna get the car checked out by a mechanic for peace of mind coz i dont wanna lose my baby to a silly thing. Thanks Heaps!!! Very Happy
Previous Topic:ST205 Is there different models?
Next Topic:gt4 gearbox
Current Time: Fri Nov 20 13:34:57 UTC 2026
Total time taken to generate the page: 0.02079701423645 seconds
