Toymods » Tech & Conversions » intercool
pulcino
Mackay QLD
icon6.gif  intercool Fri, 03 January 2003 20:30 Go to next message
I am currently not running an intercooler with my 4age turbo. My question is what difference do you think I should expect by ading an intercooler even if it only be a 4agze one Very Happy Very Happy
rollaboy
Coffs
Re: intercool Fri, 03 January 2003 23:04 Go to previous messageGo to next message
What turbo are you using??
Did you turbo a 4AGZE??
Have you done any internal work??
xxpunkerxx
Re: intercool Sat, 04 January 2003 11:25 Go to previous messageGo to next message
I would say an intercooler would make your engine last alot longer unless you are using methanol!!
Even the little gze one would make a diference
pulcino
Mackay QLD
Re: intercool Sat, 04 January 2003 12:54 Go to previous messageGo to next message
It is just a 4age with a ct20 turbo.I already run water methanol.I put the 4agze intercooler on went for a run.The intercooler robbed between 3 to 4 pounds. I came home and adjusted that.Took it for another burn. It feels like the mid to topend pull has increased a bit but I was never expecting much performance wise. It definately keeps it heaps cooler.
After a few good power runs the intake manifold is still good to touch before there was no chance.
mx83toy
Re: intercool Sat, 04 January 2003 23:42 Go to previous messageGo to next message
i'd say a good response to your question would be as you've discovered you'll get some restriction in boost (the has to be forced through the cooler now) dont expect to many power gain but expect less power degredation.....
try a bigger coola i might put my chaser one up for sale soon keep an eye out or pm me
Remedy
Southern Sydney
Re: intercool Sun, 05 January 2003 13:41 Go to previous messageGo to next message
I think as been said, an intercooler will not increase performance by itself.
It will howerver make room for further mods or higher boost levels.
Re: intercool Mon, 06 January 2003 00:51 Go to previous messageGo to next message
As a matter of fact, a good intercooler can increase performance by itself simply because it makes the inlet charge denser. Higher density = more oxygen = more power! In some cases you may have to tune the engine to take advantage of this (eg more ignition advance), but generally speaking you will get at least some extra power simply by installing an intercooler.
Remedy
Southern Sydney
Re: intercool Mon, 06 January 2003 02:32 Go to previous messageGo to next message
Wow.... didn't know that.
Thats a good excuse for me to buy that Front Mount.
How exactly does it make the inlet charge denser? I thought they were basically a cooling device only.
MR. 2
Parramatta
Re: intercool Mon, 06 January 2003 02:56 Go to previous messageGo to next message
its denser because there is more air flow the more it can put through the inlet the denser it becomes think about it a larger pipe fits more then a smaller one, so therefore bigger is better to a degree. to big = turbo lag. anyways thats another story
MR. 2
Parramatta
Re: intercool Mon, 06 January 2003 03:01 Go to previous messageGo to next message
and also it becomes desnser because the i/c will reduce the temp. think about it like this when u have a cup of water what happens when its heated its steam then u put it in a frigde or frezer it becomes ice therefore its denser then steam. just a thought! have fun hope this helps Very Happy
mx83toy
Re: intercool Mon, 06 January 2003 04:05 Go to previous messageGo to next message
yeah...thats true depending on wether ect ect... which being in oz 99.9 % of the time you'll make gains Very Happy
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: intercool Mon, 06 January 2003 05:50 Go to previous messageGo to next message
The colder air is the more dense it is, ie there is more air in a given volume. Therefore there is more oxygen in the given volume (the volume will end up being one of your cylinders), which means more fuel can be added, and then when you light it it will make a bigger bang & you will have more power.
[Updated on: Mon, 06 January 2003 05:51]
RWDboy
Re: intercool Mon, 06 January 2003 07:21 Go to previous messageGo to next message
When air is colder it also has less of a tendency to pre-detonate, meaning you can advance the timing a bit more which is good for power (to an extent).
You could probably run a hell of a lot higher boost pressure too if you wanted to.
Re: intercool Mon, 06 January 2003 07:34 Go to previous messageGo to next message
Correct. Intercooling will also increase the life of your engine, so it's just a good idea no matter which way you look at it! Considering how cheap OEM coolers are these days, there's no reason not to do it.
pulcino
Mackay QLD
Re: intercool Mon, 06 January 2003 10:48 Go to previous messageGo to next message
Well now that I am running the intercooler. Is there any advantage or disadvantage in disconnecting the water methanol injection?
Re: intercool Mon, 06 January 2003 12:52 Go to previous messageGo to next message
If it's there, you might as well leave it. Water injection will cool the inlet charge even further than the intercooler alone can, as as we have already established a cool inlet charge is a good thing. Smile
mx83toy
Re: intercool Mon, 06 January 2003 23:05 Go to previous messageGo to next message
BigWorm wrote on Mon, 06 January 2003 16:50
this is a great exlaination of wots happening Smile
more about water injection though i'll start a new thred
pulcino
Mackay QLD
Re: intercool Tue, 07 January 2003 00:28 Go to previous messageGo to next message
Does this mean that now that the air is more dense that I need to richen the mixture up?
RWDboy
Re: intercool Tue, 07 January 2003 04:59 Go to previous messageGo to next message
Yeah the mixture would be slightly leaner now so you'd have to enrich it to get it back to a decent ratio.
Re: intercool Tue, 07 January 2003 05:33 Go to previous messageGo to next message
Actually it depends how the air is metered by your engine. If it uses a MAF sensor (mass airflow), no re-tuning is required because the ECU knows what mass of air is being consumed, regardless of density. If it's using a flapper-type airflow meter it's a different story, as these can only measure the volume of air going past, not the mass.
RWDboy
Re: intercool Tue, 07 January 2003 05:38 Go to previous messageGo to next message
Stock 4A-GE engines (at least 1st gen) use a air volume meter, not mass - same as 1st gen 3S-GE.
I dunno about the later 4A-GEs though (100kW 4A-GE, 20v etc etc)
pulcino
Mackay QLD
Re: intercool Tue, 07 January 2003 05:39 Go to previous messageGo to next message
Maf how cool is that Cool It seems to be running sweet as , probably the best it eva has.
gold28
Madrid - Spain
Re: intercool Wed, 08 January 2003 12:18 Go to previous message
If you want to know exactly how much effect an intercooler makes, do the maths. The difference in density directly proportional to the temperature ratio.
For a turbo/supercharged car, use the following equation.
Pressure Difference = (inlet air temp/outlet air temp)*pressure ratio.
Note that temp is in Kelvin, Kelvin = Celsius + 273
in your case, measure the inlet temp after the turbo, and divide by the outside air temp. My guess is that at say 0.5bar (7psi) boost (pressure ratio = 1.5), you will have an inlet temp say 80 degrees greater than ambient.
Density difference = (298/(298+80))*1.5 = 1.2
= 1.2 times non turbo density.
If you put on an intercooler that knocks off say 50 degrees, the difference equals
Density difference = (298/(298+30))*1.5 = 1.3
= 1.3 times non turbo density.
theoretically if your 4age puts out 100kw, with the turbo, it will put out 120kw and with an intercooler it will put out 130kw.
Not bad huh. Without making your turbo work any harder, you gained about half the increase that just the turbo gave you.
Have fun and ceep cool.
ps. have you seen the yellow RA28 with the twin turbo lexus V8 in it. He uses a liquid/air cooler and runs his coolant pipes through an eski full of dry ice. This gives him inlet temperatures a few degrees less than ambient, you do the maths.
Previous Topic: indicators rooted/ ta22 any idea's?/ NOW fixed :O)
Next Topic:Reverse lights MA70 GT
Current Time: Fri Nov 20 21:35:40 UTC 2026
Total time taken to generate the page: 0.0066468715667725 seconds
