Toymods » Tech & Conversions » AE71 LSD help
ae71bandit
melbourne
September 2005
AE71 LSD help Sat, 24 September 2005 10:41 Go to next message
what do u need to do to put an lsd in an ae71?
Im also wanting to make the suspension nice n hard for drifting,
what would be the cheapest way to get it harder.
chrisellis
Re: AE71 LSD help Sun, 25 September 2005 09:07 Go to previous messageGo to next message
if ur doing it on the cheap, weld the diff up. as for suspension, buy harder springs and shocks. They are interchangable with spoontah stuff, which you will find lots of around. stiffer the better for d1 action Razz
RT72
melbourne
May 2005
Re: AE71 LSD help Mon, 26 September 2005 01:39 Go to previous messageGo to next message
so is the suspension on the ae71 the same as a sprinter,
chrisellis
Re: AE71 LSD help Mon, 26 September 2005 02:01 Go to previous messageGo to next message
the chassis are the same, and therefor the suspension will fit, i think the struts are a little different and ppl run sprinter front struts or is it just the strut top thats different?, but yeah the front struts i hear are a direct bolt up, and yeah the springs and shocks for a sprinter both front and rear will fit, for the front im not sure if it will fit without running sprinter strut's but its worth your while doing that so u can get all the other adjustable goodies, rca's, camber tops, control arms and the rest that suit a sprinter, the steering racks are identical also i think. hope this helped. Chris
truenosedan1
July 2005
Re: AE71 LSD help Mon, 26 September 2005 03:25 Go to previous messageGo to next message
struts are different
ae86 run different steering arm! so be sure to change that!
rack mounts are same distance apart, but rack shaft is shorter
to put lsd in ae71, you need to go to a wrecker and get a t18 diff (preferably with swaybar mounts) and then pm me, and i will get you a 2 way lsd straight out of japan, that will bolt straight in! Very Happy
cheapest way to "make it harder" would be springs
the cheapest way to reduce body roll would be swaybars!!
pm me and i will help you with the suspension side of things...thanks
Very Happy
chrisss
melb
Re: AE71 LSD help Mon, 26 September 2005 05:38 Go to previous messageGo to next message
how much is the 2-way for a t series worth???
truenosedan1
July 2005
Re: AE71 LSD help Mon, 26 September 2005 07:41 Go to previous message
$1250 for a trd 2 way pm me
Previous Topic:Turbo 4age 16v
Next Topic:Possible problem with drivetrain?
Current Time: Fri Nov 20 13:35:06 UTC 2026
Total time taken to generate the page: 0.48689389228821 seconds
