Toymods » Tech & Conversions » 86 Suspension - front strut noises over bumps
Hachi2Muchi
August 2005
86 Suspension - front strut noises over bumps Sun, 25 September 2005 03:18 Go to next message
Hi
Basically, when i go over the smalest bump at moderate speed (50km) there is painful hitting noise coming from the front struts. Could it be worn bushes and metal is hitting metal? Springs and shocks are really soft, it may be worn out.
Any help/advice would be great!
Thanks in advance
chrisellis
Re: 86 Suspension - front strut noises over bumps Sun, 25 September 2005 08:58 Go to previous messageGo to next message
if it sounds like metal on metal, then u really need to look for where this could be happening. Pull the suckers out (or is it just one side) and have a look.
Driftspec
Re: 86 Suspension - front strut noises over bumps Sun, 25 September 2005 11:25 Go to previous messageGo to next message
Sounds like warn bushes, mine is a bit noisy and yeah its because the bushes are f'd... metal on metal.
WiLo
wollongong NSW
Re: 86 Suspension - front strut noises over bumps Sun, 25 September 2005 11:39 Go to previous messageGo to next message
look at passenger side front wheel well, you might find that the wheel is hitting onto the chasis
yrhkira
June 2005
Re: 86 Suspension - front strut noises over bumps Mon, 26 September 2005 02:17 Go to previous messageGo to next message
Is the suspension OEM stock?
parrot
Re: 86 Suspension - front strut noises over bumps Tue, 27 September 2005 04:37 Go to previous messageGo to next message
Or the nut that holds in the insert may be loose allowing the insert to move around inside the strut. Try and tighten it with some stilsons.
truenosedan1
July 2005
Re: 86 Suspension - front strut noises over bumps Tue, 27 September 2005 14:40 Go to previous message
it will be the top bearing in the strut top
just located my same problem!!!
check it out!!
Previous Topic:7M-GTE crazy revving problem...
Next Topic:2tgteu or 4agte?? i cant decide
Current Time: Tue Sep 15 04:30:47 UTC 2026
Total time taken to generate the page: 0.0044858455657959 seconds
