Toymods » Tech & Conversions » HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50)
bloody_huge23
HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50) Sat, 04 January 2003 02:22 Go to next message
Hey,
Just as the subject says how do you convert the cable clutch on a ke30 to a hydrolic clutch when using a T50 from a AE71.
What parts do i need?
Thanx heaps,
Adam
Ta22 20 valve
Re: HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50) Sat, 04 January 2003 03:48 Go to previous messageGo to next message
you can still buy new, ta22 clutch master cylinders from auto pro and they should fit easy with some mods to the fire wall and clutch lever, all you will need then is brake line to plum it up
CrAiGzEE
south of the big smoke
Re: HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50) Sat, 04 January 2003 10:50 Go to previous messageGo to next message
i have a clutch assembly off a 1ggte supra ya should be able to mod up quite easily
let me know if ya interested
craig
EMP-2TG
Carlingford, Sydney
Re: HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50) Sat, 04 January 2003 23:05 Go to previous messageGo to next message
go buy a new ta22 one,
there are dimples in the fire wall where u drill out holes for the bolts
and use a small hole saw to cut out the center hole
its all easy till u get to working out the pedal
i have a ta22 top half with a ke30 pedal welded on half way down
if u need any help just ask and ill go look at mine Smile
bloody_huge23
Re: HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50) Sat, 04 January 2003 23:11 Go to previous messageGo to next message
Im getting the pedal box and master and slave cylinder from the place where im getting the GB from...(AE71)
Would i need anything else?
Thanx,
Adam
Ta22 20 valve
Re: HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50) Sat, 04 January 2003 23:27 Go to previous messageGo to next message
hydraulic lines
bloody_huge23
Re: HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50) Sun, 05 January 2003 00:00 Go to previous messageGo to next message
Where would i get these lines from?
The Car im getting the master slave and pedal box out of.?
Or do i buy brand new ones...?\
Thanx,
Adam
EMP-2TG
Carlingford, Sydney
Re: HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50) Sun, 05 January 2003 06:42 Go to previous messageGo to next message
just buy it new
wont cost much
just go to a brake and clutch place
bloody_huge23
Re: HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50) Sun, 05 January 2003 09:29 Go to previous messageGo to next message
So what do i get if i buy all this stuff...
How much and would it be to convert from cable to hydro?
If i got the pedal box, lines and master and slave cylinder from the Ae71(where im getting the box from) wouldnt this make the whole system into hydro? Or would this still be converting it from cable...
Someone once said its bad to convert should replace components.
Have you had any trouble Josh or anyone at all had trouble when doing this?
Thanx,
Adam
(PS) anything else im forgetting?
EMP-2TG
Carlingford, Sydney
Re: HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50) Sun, 05 January 2003 11:44 Go to previous messageGo to next message
i havent had any trouble with mine
which is a whole setup lifted from a ta22
it cost me maybe $25 or somthing
nothing much really
chrisss
melb
Re: HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50) Sun, 05 January 2003 14:40 Go to previous messageGo to next message
I would doubt a ae71 pedal box would fit a ke30 body shell they are a completely new model - but you never know what will work until you try it. I used a clutch master cyl and lines from an ae86 on my ke70 when i swapped to the t-50.
Grega
melbourne.victoria.austra...
Re: HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50) Sun, 05 January 2003 20:22 Go to previous messageGo to next message
the ta22 and ke55 pedal boxes are different (found that out) - ke30 one might be the same as ta22 so might be less of an issue.
at worst remove the clutch pedal assy from the side of the pedal box and weld it to the ke30's - easy
Re: HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50) Mon, 06 January 2003 10:45 Go to previous messageGo to next message
I did mine last week, not too hard and didn't cost me a cent. I used the original ke55 clutch pedal, drilled a hole in it for the lever to go through, and made a custom lever to clear the pedal box. Nothing TOO hard really, now my only problem is that the 2T-C is even more gutless than the 4k it replaced!
TurboCelica
Re: HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50) Mon, 06 January 2003 11:12 Go to previous messageGo to next message
hahahah i would have thought the 2t-c wuld be a better bet than the 4k-c altho my 4k-c never said never no matter what i threw at it
have to almost be the best (strongest) engine ever made!!!
(i dont mean powerfull i mean never die)
Re: HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50) Mon, 06 January 2003 11:33 Go to previous messageGo to next message
It wasn't that my 4K had completely died - it was just the lack of balls, the bearing noise and the oil consumption that inspired me, plus the fact that I was about to take the TA22 to the crusher anyway (an ex paddock car that had been set on fire just too many times!). The whole reason a 4K won't die certainly ain't because its a strong engine - take a look at the rods, crank, etc! However, the extreme lack of balls means there just isn't enough stress on anything to make it fall over - seems to be a trait with a lot of the more pedestrian toyota engines. Likewise geminis, datsuns, etc. - the kind of treatment that I and many others have given to these cars is seriously unthinkable, yet they will always sit up and ask for more. Half the fun is trying to overcome the lack of balls with brutal treatment and still not breaking anything!
bloody_huge23
Re: HOW TO: Convert Cable Clutch into Hydrolic Clutch (KE30-T50) Tue, 07 January 2003 09:37 Go to previous message
Hey,
So do you all recommend to buy a slave, master cylinders and the hydrolic lines brand new?
And use the standard pedal box...
Thanx,
Adam
Previous Topic:insurance for 1g-gte ra23
Next Topic:1g gte?
Current Time: Sat Nov 21 00:29:35 UTC 2026
Total time taken to generate the page: 0.0055480003356934 seconds
