Toymods » Tech & Conversions » Lexus AFM mod
whatthe?
August 2005
Lexus AFM mod Sun, 25 September 2005 13:59 Go to next message
Hi all,
can anyone tell me if there are any physical modifications necessary to make the lexus AFM fit where the old 7MGTE one was? I know I have to upgrade fuel pump, injectors and I'm better off getting an s-afc, but does anything need to be fabricated to make the afm fit in the first place?
whatthe?
August 2005
Re: Lexus AFM mod Sun, 25 September 2005 14:13 Go to previous messageGo to next message
ps to clarify a bit;
will i need to make an adaptor to fit a filter? the lexus afm comes with a round fitting on one end but only the rectangular honeycombed job at the other end.
whatthe?
August 2005
Re: Lexus AFM mod Sun, 25 September 2005 14:36 Go to previous messageGo to next message
Please disregard, found HKS filter adaptor and filter on ebay to suit lexus AFM.
Danners
Central Coast, NSW
Re: Lexus AFM mod Sun, 25 September 2005 22:36 Go to previous messageGo to next message
I'm interested in seeing how you go with this. I have the Lexus AFM, 550cc injectors, Walbro fuel pump, and S-AFC (already installed) for this mod but haven't installed it yet due to lack of knowledge
Dan
1200det
Re: Lexus AFM mod Sun, 25 September 2005 22:49 Go to previous messageGo to next message
The lexus AFM is a straight swap even the electrics or if you desire you can swap the 7M AFM electrics across to the Lex AFM.
Now there a direct swap physically but dont think you can use the AFM without supporting mods like the 550cc Injectors etc
Danners
Central Coast, NSW
Re: Lexus AFM mod Sun, 25 September 2005 22:53 Go to previous messageGo to next message
1200det wrote on Mon, 26 September 2005 08:49
Yeah i know that part, i guess i'm worried about the car running too lean once i install everything. Is a rising rate FPR required for this mod, or can you get away with not using one?
Dan
1200det
Re: Lexus AFM mod Sun, 25 September 2005 22:56 Go to previous messageGo to next message
I would advise a FPR although i havent personally used a rising rate nor do our fellow yanks.
LEX AFM and 550cc Injectors , FPR , J-pipe restriction removed and a SAFC for what you said to make sure your not running lean as these mods dont always do the same thing as it has on other 7M`s
Danners wrote on Mon, 26 September 2005 08:53
Dan
Danners
Central Coast, NSW
Re: Lexus AFM mod Sun, 25 September 2005 22:59 Go to previous message
1200det wrote on Mon, 26 September 2005 08:56
J-pipe restriction?? I haven't heard of this one before.
Have you installed the AFM mod on any of your 7M's before?? If so, what kind of performance increase did you notice?
Dan
Previous Topic:What the hell does a charcoal chamber do?!
Next Topic:2tgte + ct9 ????
Current Time: Wed Aug 5 02:04:28 UTC 2026
Total time taken to generate the page: 0.1343309879303 seconds
