Toymods » Tech & Conversions » D and T series diffs
ROTAROLA
April 2005
D and T series diffs Sun, 25 September 2005 14:36 Go to next message
how would u tell the difference between the two if u just have the diffs and not the cars??
ive got a diff from a TA22 but im not sure if its a T or a D.
help would be great.
cheers Preston..
ra23celica
Re: D and T series diffs Sun, 25 September 2005 14:53 Go to previous messageGo to next message
You will have to unbolt it and measure the diameter of the crown wheel.....6.7 inch is a T series, about 6.3 inch is a D series, if memory serves me correctly.
ROTAROLA
April 2005
Re: D and T series diffs Sun, 25 September 2005 15:38 Go to previous messageGo to next message
ok ill give it a try.
it also says 28 on the front of the diff. with 10 nuts.
if that helps.
ra23celica
Re: D and T series diffs Mon, 26 September 2005 02:17 Go to previous message
28 'might' refer to the final drive ratio, but unless there is a T or a D stamped somewhere on the outside casing, it does not help you tell what size diff you have, the best way (other than knowing the build plate of the car that the diff originally was fitted too, is to unbolt the sucker and measure the diameter of the crown wheel.
I don't think too many D series diffs came to OZ, they were mainly in 1970 to 1971 TA22's so its likely that you have a T series, but you can't be sure until you measure.
Previous Topic:RA40 diffs
Next Topic:RA60 Struts/Shocks - What other cars fit in.... ???
Current Time: Fri Nov 20 13:47:48 UTC 2026
Total time taken to generate the page: 0.022063970565796 seconds
