Toymods » Tech & Conversions » HELP!! 4agze Shim sizes
DacBietAE86
HELP!! 4agze Shim sizes Mon, 26 September 2005 01:09 Go to next message
Guys i need help..
i pulled all the shim buckets out and now they are all mixed up.To the eye they all looked the same.Now i know there is two size shims on the buckets , either the inlet side is thicker or the exhaust side is thicker..
Does anyone know...
so i can put it back together..
thanks heaps
any help would be much appreciated
JNR 13B
Re: HELP!! 4agze Shim sizes Mon, 26 September 2005 06:10 Go to previous messageGo to next message
bump
TE72_Turbo
Re: HELP!! 4agze Shim sizes Mon, 26 September 2005 06:24 Go to previous messageGo to next message
There could be a whole multitude of different thickness shims to get the correct clearance at each cam lobe, and you are gonna have a hell of a fun time working them out Laughing
DacBietAE86
Re: HELP!! 4agze Shim sizes Mon, 26 September 2005 07:20 Go to previous messageGo to next message
crap!!
from my understanding from someone ,that there was only two thicknesses
The exhaust side and the inlet side..
Can anyone confirm please...
beige_bandit
September 2005
Re: HELP!! 4agze Shim sizes Mon, 26 September 2005 07:28 Go to previous messageGo to next message
the tolerence for the exhaust will be different from the
inlet, but there is not only two sizes, due to wear
that occurs in and about the cam lobes, bucket's, shims
and valve stem you may need 16 different sizes,
do you have a tool to measure shim thickness?
find out what the vavle clearence is supposed to be!
DacBietAE86
Re: HELP!! 4agze Shim sizes Mon, 26 September 2005 07:36 Go to previous messageGo to next message
great!!now im screwed...
thanks for all your help beige_bandit. appreciate it
Does anyone know if the valve clearance is the same for the 100kw and the gze?
thanks again guys
TE72_Turbo
Re: HELP!! 4agze Shim sizes Mon, 26 September 2005 08:59 Go to previous messageGo to next message
Yes they are.
FASTFOO
melb
February 2005
Re: HELP!! 4agze Shim sizes Mon, 26 September 2005 12:44 Go to previous message
If the clearance's were right before you should be able to get them right now without getting new shims.
just put them in anywhere and measure the gaps on each valve wright them down then workout which sims you need to put wear so you get the right clearance's.
Its a pain but you will never mix up shims again Wink
MATT.
Previous Topic:seca sx lights
Next Topic:gearbox conversion
Current Time: Sat Sep 12 21:18:37 UTC 2026
Total time taken to generate the page: 0.0055830478668213 seconds
