Toymods » Tech & Conversions » rotating a ct-26
steve-O
wollongong
rotating a ct-26 Mon, 26 September 2005 02:11 Go to next message
hey guys i need to rotate my ct-26 to the correct position for the oil drain for my 3t-gte, just wanted to know how to go about it. i was told it was dowled so i guess i'll have to remove the shaft, but i dont have anything that will fit the fasteners on the shaft. can anyone help me?
steve-O
TA22-3SGTE
MACKAY
Re: rotating a ct-26 Mon, 26 September 2005 11:34 Go to previous message
No do not remove the shaft , remove the V band on the exhaust side and the large circlip on the comp side , the comp cover should come off with a bit of a twist and tap , be careful not to bump the wheel you can then remove the little pin so the housing can be rotated , the exhaust housing usually seizes on fairly tight so you may have to soak a bit of penetrating oil into it overnight then try tapping it off , sometimes it takes quite a bit of tapping and soaking to get it free .
Trevor
Previous Topic:gearbox conversion
Next Topic:dry sump kit for the 3sgte
Current Time: Mon Nov 2 16:38:37 UTC 2026
Total time taken to generate the page: 0.18774509429932 seconds
