Toymods » Tech & Conversions » I need som help
turbocharged_camery
Townsville QLD
icon9.gif  I need som help Mon, 26 September 2005 03:13 Go to next message
hey can any one help me to turbo my 3sfe 91 camry. ive been looking on the net and it all leads to dead ends so can someone help. with parts or any kind of information to help me. and wot is the difference between the 5sfe and the 3sfe.
Roundy
Dubbo
April 2005
Re: I need som help Mon, 26 September 2005 04:33 Go to previous messageGo to next message
probably easiest way would be to pull out the 3S-FE and put in a 3S-GTE from an MR2 or GT4...would probably wind up cheaper as to turbo u would need turbo, manifold, fuel system upgrades, computer, rebuild etc etc etc to get the most out of it, also probably brake upgrades to get it past an engineer.
Tho i have a CT26 turbo (from a 3S-GTE) sitting at home with manifold...turbo would need a rebuild, and it might fit on your head, tho not sure.
Not entirely sure about the differences of 5s-3s tho the 5S is 2.2l as opposed to 2l and i think that is only cause it has a longer stroke
Regards Nathan
smt_007
Re: I need som help Tue, 27 September 2005 03:30 Go to previous message
At the end of the day it would be cheaper to get a 3sgte front cut and get it installed, rather than 3sfe youll be up for the same money once you get custom sump, turbo and manifold...etc etc The 3sfe wont last long, one guy had it upto 10 psi and it melted the pistons, 6-7psi would be max. If your thinking of rebuilding your camry unless you know someone to do it for you, it wont be cheap and you again are better off getting a 3sgte halfcut.
[Roundy] is right on the money Wink , i personally know 4 camry turbo owners and it still isnt a cheap conversion with the halfcut route, with any conversion something will always go wrong. Also another mate decided to turbo his 3sfe 3.5k later he had a turbo and piping, intercooler, gt4 sump and realised he should have bought a half cut because when its done it will cost him 5k and that a turbo 3sfe, which wont handle much boost anyway and could melt the pistons invlolving more costs Confused .
[Updated on: Tue, 27 September 2005 03:36]
Previous Topic:is t50 gearbox will bolt onto 20v silver top engine ?
Next Topic:KE70 and AE86 steering racks
Current Time: Tue Oct 13 11:05:24 UTC 2026
Total time taken to generate the page: 0.048857927322388 seconds
