Toymods » Tech & Conversions » sc14 max rpm
redzed
April 2005
sc14 max rpm Mon, 26 September 2005 08:29 Go to next message
hey guys
just a quick question:
What are people's opinions on maximum blower rpm for an SC14? Ive read a couple of different opinions on the subject, and was just wondered what people have experienced? What actually happens if it spins too fast? Is it possible to have the blower rebuilt in such a way so that it is able to spin faster safely?
Mr DOHC
Re: sc14 max rpm Mon, 26 September 2005 08:38 Go to previous messageGo to next message
blower speed is 14K.
hearts up the air too much other wise
Re: sc14 max rpm Mon, 26 September 2005 09:00 Go to previous messageGo to next message
and then the extra heat damages the teflon layer?
more than one person has suggested water injection to help cool the charge and to help seal the rotors a little...
spinning faster is not a great idea, but if it is not too often, you might want to chance your luck Wink
they are not the most efficient SC in the world tho.. being a straight lobe roots style...
nick.parker
January 2005
Re: sc14 max rpm Mon, 26 September 2005 09:35 Go to previous message
I know of several people who've had 'teflon coating failures' most if not all running their SC12s/SC14s @ > 10K RPM.
I read some time ago that 10K RPM was considered the maximum for by 'some authority' on the SC12. So I've taken this on board.
Both the SC12 and SC14 setups I've have have always been sized to give max blower RPM (around 10K) at engines max rpm (7500rpm on the 4AGZE) - not that they get revved that high very often.
There is a place (In Perth I believe - I have yet to try and get the details) that can re-coat the SC lobes with a higher spec coating. They are used by Sprintex.
I will be looking into this as I'm not sure how well my SC14 is going to last at up to 20psi boost (done at with a 1.4x SC drive ratio)
Cheers, Nick.
Previous Topic:4ke setup on 3k compared to 4k
Next Topic:Turbo 4age 16v
Current Time: Fri Nov 20 13:34:24 UTC 2026
Total time taken to generate the page: 0.0051138401031494 seconds
