Toymods » Tech & Conversions » Rover V8 CORONA CONVERSION
sheam
March 2005
icon10.gif  Rover V8 CORONA CONVERSION Mon, 26 September 2005 11:11 Go to next message
I have heard somewhere (can't remember where) someone talking about a conversion of this kind. I have a RT81 Corona myself and are looking at doing a conversion. It will be a paddock bomb so the conversion will definitly not have to be legal. I have managed to find myself a 3.5 litre Rover V8 complete with twin SU's and by the looks of it, it should fit. Any advice would be greatly appreciated. cheers
Re: Rover V8 CORONA CONVERSION Mon, 26 September 2005 12:52 Go to previous messageGo to next message
Well, personally I wouldn't bother with a pom V8, especially such an old one like that, but if you've got the bits there, just haul out the old engine, stick in the 'new' one, and see how it looks like it might fit.
Re: Rover V8 CORONA CONVERSION Mon, 26 September 2005 12:58 Go to previous messageGo to next message
sheam wrote on Mon, 26 September 2005 21:11
stick it in, weld the block to the crossmember, get some twine to operate the clutch and/or accelerator and away you go Very Happy
seriously, if it's for a paddock bomb, grab a stick welder, a few bits of angle iron, and go nutes Very Happy
Rex_Kelway
Re: Rover V8 CORONA CONVERSION Mon, 26 September 2005 13:01 Go to previous messageGo to next message
Sheam,
Although The Rex is hard pressed to find an actual qusestion, if you have the Rover 8 then by all means put it in something.
Its not a bad motor at all, its light, smooth, well proven and sounds brilliant. Sure its forged by a blacksmith with wrought iron and granite but it should prove a good hacker.
Re: Rover V8 CORONA CONVERSION Mon, 26 September 2005 14:21 Go to previous messageGo to next message
is the rover 3.5 an alloy block? or was that the later leyland 4.x litre V8s?
i guess an RT81 making strange V8 rumblings is going to look a lot funnier than an actual rover - plus you won't be handicaped by rover's (and anyone else british) ability to make automotive electrical systems that are inherently faulty and prone to undiagnosable errors.
Re: Rover V8 CORONA CONVERSION Mon, 26 September 2005 14:35 Go to previous messageGo to next message
For anything but a paddock bomb, I'd say you're nuts to spend any time at all with a Rover V8. Truly horrible things they are. They were probably great back in their day, but now that they're all old and worn out they give no end of trouble. If you like mystery leaks and unexplained engine fires, the Rover V8 is the engine for you. But since it's a paddock bomb these failings are probably a minor concern. Smile
Re: Rover V8 CORONA CONVERSION Mon, 26 September 2005 21:06 Go to previous messageGo to next message
It fits but there's no room for the exhaust on the driver's side - I think the exhaust port for one of the rearmost cylinders is virtually smack bang up against the steering box.
Chat to "Allan" - he did this very conversion in a weekend. He has pics.
That same RT81 is now getting a TTV6.
ZZT231
melbourne.vic.au
Re: Rover V8 CORONA CONVERSION Mon, 26 September 2005 22:22 Go to previous messageGo to next message
gianttomato wrote on Tue, 27 September 2005 07:06
I wonder what Allan hasn't done in a weekend Wink
filthman
Heathmont, Melbourne, Vic
Re: Rover V8 CORONA CONVERSION Mon, 26 September 2005 22:33 Go to previous messageGo to next message
There not the most powerful of engines, but I do know of a few that pull some big revs when built right. And there light as buggery. There is absolutely no weight in the block. The Leyland 4.4 alloy V8 great if you can find one. Its slightly larger in the V (wider) and its nearly a litre bigger.
hmmm paddock basher - locked diff, line lockers, big burnouts!!!
sheam
March 2005
Re: Rover V8 CORONA CONVERSION Tue, 27 September 2005 06:02 Go to previous messageGo to next message
alan sounds good. i will try to contact him. also i would use any aussie 8 over anything those cricket bat wielding englishmen have made , but if you've seen the engine bay in this thing you'll understand my reasoning.
M.W.P.
Rocky Mountains, Canada
Re: Rover V8 CORONA CONVERSION Tue, 27 September 2005 08:16 Go to previous messageGo to next message
sheam wrote on Tue, 27 September 2005 15:32
The Rover 3.5L V8 was actually an American engine (cant remeber which company).
For some reason they didnt want to use it so the design and tooling bits were sold to Rover.
But American V8s suck too Wink
Re: Rover V8 CORONA CONVERSION Tue, 27 September 2005 09:05 Go to previous messageGo to next message
It was based very heavily on the Buick 215. Rover bought the rights to build the motors when Buick stopped making them in the early 1960s.
http://www.amacointernational.com/images/Rover_V8_to_911_ta_15cm.jpg
[Updated on: Tue, 27 September 2005 09:11]
Re: Rover V8 CORONA CONVERSION Tue, 27 September 2005 09:10 Go to previous messageGo to next message
I don't think exhausts fouling on anything will be a problem if it's a paddy basher - personally I'd be cutting a hole in the 1/4 panel and having the exhausts exit behind the front wheels Smile
And as stu said, if it's just for fun in a paddock grab some measurements of mounts from alan and weld everything together. Extensive use of duct tape and cable ties is strongly encouraged.
shovelnose
Re: Rover V8 CORONA CONVERSION Tue, 27 September 2005 11:25 Go to previous messageGo to next message
I think Buick did start making the engine initially and then they decided to drop it as it was expensive to make. They went back to an iron block design. A visiting Rover engineer saw an opportunity and the rest (with a big thank you to Lucas the Prince of Darkness), is history Razz Laughing
sheam
March 2005
Re: Rover V8 CORONA CONVERSION Tue, 27 September 2005 11:53 Go to previous messageGo to next message
i was actually thinking of welding up some custom pipes exiting through the bonnet and making up a home made flame thrower unit (tut tut) from some old spark plugs i have lying around. i may also invest in a fire extinguisher.
EVOSTi
cambo
      no
Re: Rover V8 CORONA CONVERSION Tue, 27 September 2005 11:56 Go to previous message
ive seen one in an early corolla so i dont see why a corona would be a problem.
Previous Topic:2tgteu or 4agte?? i cant decide
Next Topic:4A GZE Intake Manifold
Current Time: Fri Nov 20 23:49:33 UTC 2026
Total time taken to generate the page: 0.0060009956359863 seconds
