Toymods » General Car Talk » Gear ratio calculator
Chris Davey
sunny coast, qld
Gear ratio calculator Mon, 26 September 2005 12:43 Go to next message
http://www.et-studios.com/motorsports/gears/gears. html
Hi guys,
Been fiddling with this gear ratio calculator as my current gearing setup means that I have to change into OD with about 50m or so left before the end of the drag strip. I have put in my current figures but the calculator is slightly higher than what I have experienced.
The only thing I can think of that could effect it would be the big head wind on the day of racing and also that Willowbank is infact slightly uphill.
Anyone, whack in your details and tell me if it is correct.
If you need to know what diameter your tyres are use
http://www.miata.net/garage/tirecalc.html
Chris
Blown86
Re: Gear ratio calculator Mon, 26 September 2005 17:22 Go to previous messageGo to next message
Don't know if this will help??
http://www.locost7.info/gearcalc.php
Smile
Chris Davey
sunny coast, qld
Re: Gear ratio calculator Tue, 27 September 2005 00:52 Go to previous messageGo to next message
Hmm, looks good. Will try it when I get home.
M.J.H
Re: Gear ratio calculator Tue, 27 September 2005 05:25 Go to previous messageGo to next message
http://www.hewland-engineering.co.uk/svga/ratio.ht m
Maybe this will help.
ke382TG
Re: Gear ratio calculator Tue, 27 September 2005 05:51 Go to previous message
I just ran my numbers through the link Chris and mine come pretty close to what I run on the track, very close actually.
It also indicates that when my new tyres arrive it should be spot on for crossing the line only a few rpm before redline in 4th Smile
Previous Topic:What 5speed can i put behide my corona
Next Topic:parts from Bursons, do u have to be a tradey?
Current Time: Tue Oct 20 01:06:31 UTC 2026
Total time taken to generate the page: 0.0044710636138916 seconds
