Classifieds » Car/Engine Electronics & Audio » FS: LEDs available for you car t10 wedge bulbs, brake,reverse/parker light bulbs, interior light!
AE86T
Forums sponsor
FS: LEDs available for you car t10 wedge bulbs, brake,reverse/parker light bulbs, interior light! Mon, 26 September 2005 15:26 Go to next message
Hi Guys,
I have stock on super white LEDs, this improve the look of your vehicle drastically by whitening up the lights, while reducing current draw and well as heat discipation. All only available in WHITE.
T10 wedge type bulbs 9 LED $20.00 pair
t10 wedge type bulbs 6 LED $18.00 pair
Interior 4 LED $12.00 each
Interior 6 LED $15.00 each
1157 brake/park/reverse type bulb $30 pair
For interior light bulbs, please measure your length of the standard bulb from end to end or if its for ae86, let me know. Most number plate bulbs uses t10 wedge bulb and same for parkers.
Please visit www.visionr.com.au for pictures.
Contact sales@visionr.com.au or 0403003131
Regards
Wei
Re: FS: LEDs available for you car t10 wedge bulbs, brake,reverse/parker light bulbs, interior light Wed, 28 September 2005 04:57 Go to previous messageGo to next message
Just a warning to all - the use of LED lights on the road that are not factory fitment for taillights, brake lights, indicators etc is in fact illegal.
LED lighting for the exterior of the vehicle should be for off-road use ONLY.
Toobs
Re: FS: LEDs available for you car t10 wedge bulbs, brake,reverse/parker light bulbs, interior light Fri, 30 September 2005 11:20 Go to previous messageGo to next message
The relevant ADR only states the viewing angle and luminous intensity of these things... the following should be fine:
1. Number plate lights.
2. Parking lights.
3. All interior lights (instrument cluster, aircon controls, dome light etc).
I think reverse light would probably be ok to replace with led's too (so long as they are bright enough)
Just don't go swapping brake lights or indicators without double checking that you'll still pass ADR's.
Also led lighting will confuse the body control computer in fancy pimpmobiles like you find in the crowns and soarers.
ae86_boy
Re: FS: LEDs available for you car t10 wedge bulbs, brake,reverse/parker light bulbs, interior light Sat, 01 October 2005 10:14 Go to previous messageGo to next message
anyone know why these are illgeal, wouldnt LEDs be brighter, therefore safer at night? Confused
AE86T
Forums sponsor
Re: FS: LEDs available for you car t10 wedge bulbs, brake,reverse/parker light bulbs, interior light Sat, 01 October 2005 13:38 Go to previous messageGo to next message
For parkers, interior light and number plate light, as long as its bright enough, i dont find a problem or had any experience of anyone using leds having problems with cops, as they are white and not blue, thats just from my experience,
Regards
WEi
Toobs
Re: FS: LEDs available for you car t10 wedge bulbs, brake,reverse/parker light bulbs, interior light Mon, 03 October 2005 04:56 Go to previous message
ae86_boy wrote on Sat, 01 October 2005 20:14
A lot of the problem has to do with the fact that led's have a very limited angle of light dispersion (10-45deg usually) whereas the standard incandescent things shoot light in almost all directions.
This causes problems with things like tail-lights which use a reflector to disperse light everywhere... with led replacements you'll often only get a dot of light in the middle of the lens.
Also when you consider the limited viewing angle of led's (except for luxeons) the light output isn't comparable to incandescent bulbs yet... its just focused more.
Previous Topic:most of an EFI set sourced from a Nissan CA20E manual.
Next Topic:FS: 12" Rockford Punch 800w DVC sub
Current Time: Wed Oct 28 06:20:04 UTC 2026
Total time taken to generate the page: 0.0041129589080811 seconds
