Toymods » Tech & Conversions » 3SGE gen 2 sump capacity
Windex
Melburn!
June 2005
3SGE gen 2 sump capacity Tue, 27 September 2005 03:18 Go to next message
Whats the sump capacity of a 3SGE gen 2?
Anyone know?
Alchemist
Re: 3SGE gen 2 sump capacity Tue, 27 September 2005 10:35 Go to previous messageGo to next message
I can tell you that 4L of oil took the line to the top mark on my SW20(minus filter). That help at all?
[Updated on: Tue, 27 September 2005 10:35]
Windex
Melburn!
June 2005
Re: 3SGE gen 2 sump capacity Wed, 28 September 2005 00:40 Go to previous messageGo to next message
Thats great mate, not sure what mine is out of, but I assume a celica, cause now it is in a ta23.
Thanks dude
Windex
Melburn!
June 2005
Re: 3SGE gen 2 sump capacity Thu, 29 September 2005 07:33 Go to previous messageGo to next message
eeek, I drained mine today, got 2 liters out of it. I will assume that the dipstick is a bit buggered due to the conversion.... I will play it by ear, any other way to tell if there is enough oil in it?
Alchemist
Re: 3SGE gen 2 sump capacity Thu, 29 September 2005 08:51 Go to previous messageGo to next message
What did the dipstick say? I would put in 3-4L as that would be the desired amount, you should be OK with that.
Windex
Melburn!
June 2005
Re: 3SGE gen 2 sump capacity Thu, 29 September 2005 12:48 Go to previous messageGo to next message
The dip stick said it was almost full, but that wasnt entirly on flat ground, also the engine has been installed flat, so the base of the sump is somewhat angled, however as far as I can tell the stick would be on the higher side. I am going to put 3-4 in tomorrow once all the old crap has drained out, I am also replacing the filter, so a little more capacity there.
LiL_MiC
Melb
Re: 3SGE gen 2 sump capacity Thu, 29 September 2005 14:23 Go to previous messageGo to next message
The dipstick may be a bit wrong due to the rwd configuration, since you're not using the normal sump and such?..
I think what you want is 4 litres in there..
Possibly next time you change your oil, put in 4 litres.. Wait for it to settle down and then mark on the dipstick where the oil has come up to?
CLG
Perth, Western Australia
Re: 3SGE gen 2 sump capacity Thu, 29 September 2005 14:56 Go to previous message
Everyone has a different idea, but I'd check the oil level immediately after stopping the motor, not once it has all run back down to the sump. This is the best way to replicate a running motor and ensuring the amount of oil in "transit" plus what is left in the sump for the oil pump to pick up is enough for the motor.
In regards to actual voume in a sump, and the optimal amount, this will really depend on how hot the oil gets and how often the oil is changed. I've seen many a car with no registration of oil on the dipstick, still commuting back and forth, and while this is not optimal, the engine is not being pushed hard enough to heat or evacuate all the oil in the pan, though you only get approximately a Litre when you drain it. Ideally for any form of spirited driving, or extended service intervals, you'd want as much in there as you can safely get.
As for service intervals - as often as you can afford is a good motto. Personally, I don't like pushing oil in daily commuters past 8000Kms - I feel it exacerbates the "old oil" problems that motors develop, and the common fad to let them run to 10 000kms are simply for those people that can't deal with "round numbers". Naturally, all my cars that are actually used for more "spirited pursuits" have their oil changed at a shorter interval - I've even been known to change oil after only 20 minutes, for certain events!
Previous Topic:Diff making a clunking sound when changeing gears.
Next Topic:WANTED! 4AGZE ignition map
Current Time: Fri Nov 20 23:50:17 UTC 2026
Total time taken to generate the page: 0.0050249099731445 seconds
