Toymods » Tech & Conversions » Hub removal on AW11
nick.parker
January 2005
Hub removal on AW11 Tue, 27 September 2005 04:44 Go to next message
Ever since I've had my car, I have what appears to be a slightly buckled hub. My LH rear brake disc makes awful noises when braking.
So I got new discs, which didn't fix the problem for long.
I took the wheel and disc off and ran the car on stands.
The hub has a very slight swashing motion. If the car had been spun into a curb would it be more likely cause a damaged hub or hurt the axle or both?
If I take the hub off, firstly will it come off with 'simple' tools in my garage? Do I need a new wheel bearing if I do this?
Regards, Nick.
toof
Re: Hub removal on AW11 Tue, 27 September 2005 05:11 Go to previous messageGo to next message
you'll need to press the hub out from the stub axle. and if it comes out without some provocation ie: press then its altogeher rooted.
whilst you have it apart get new wheel bearings they are relativly cheap for the job they do.
and then youll need to press it all back together..
oh and fyi ae92 front hubs are identical to aw11 rear items.. same part number and all.
nick.parker
January 2005
Re: Hub removal on AW11 Tue, 27 September 2005 05:25 Go to previous messageGo to next message
Excellent,
Thanks for the tip, one of my colleagues at work has some AE92 hubs...Wink Is the stub axle the same too? (might be able to lay my hand on a whole AE92 assembly).
Cheers, Nick.
[Updated on: Tue, 27 September 2005 05:26]
toof
Re: Hub removal on AW11 Tue, 27 September 2005 10:23 Go to previous message
no the stub axle isnt the same.
Previous Topic:microtech vs haltechvs anyother eng manage sys
Next Topic:Removing 4age tansmission and clutch
Current Time: Sun Oct 25 20:14:21 UTC 2026
Total time taken to generate the page: 0.050117969512939 seconds
